- What's New
- Function Overview
Getting Started
- Uploading Software Packages to Release Repos
- Uploading Components to Maven Repository
- Releasing/Obtaining a Maven Component via a Build Task
- Releasing/Obtaining an npm Component via a Build Task
- Releasing/Obtaining a Go Component via a Build Task
- Releasing/Obtaining a PyPI Component via a Build Task
- Uploading/Obtaining an RPM Component Using Linux Commands
- Uploading/Obtaining a Debian Component Using Linux Commands
User Guide
- CodeArts Artifact User Guide
- Release Repos 2.0
- Self-Hosted Repos 2.0
- Release Repos 1.0
- Self-Hosted Repos 1.0
- Whitelist for All Accounts
Best Practices
- CodeArts Artifact Best Practices
- Releasing Maven Components and Archiving to a Self-Hosted Repo
- Batch Migrating Maven/npm/PyPI Components to a Self-Hosted Repo
- API Reference
- Release Repo
Self-Hosted Repo
- How Do I Upload Snapshots to a Maven Repository?
- How Do I Pull Components from a Maven Repository?
- Can I Call Software Packages in Self-Hosted Repos During Local Builds?
- What Should I Do With Error Code 500 When Uploading Maven Package for a Gradle Build?
- Why Did the Dependency WAR or JAR Files Fail to Be Downloaded?
- Why Is Error 401 Returned When Uploading Maven Components to Self-Hosted Repos?
Show all
The whitelist for all accounts includes IP address segments and several access control settings. The whitelist restricts users' access, upload, and download permissions to enhance repository security. You can set the access permission for self-hosted repos by configuring the whitelist for all accounts.
Creating Whitelist for All Accounts
- Log in to the CodeArts homepage, click the username in the upper right corner of the page, and choose All Account Settings from the drop-down list.
- In the navigation pane, choose Artifact > IP Address Whitelists.
- Click Add Address in the upper right corner of the page.
- In the displayed dialog box, select IP address or CIDR and enter an IP address.
Table 1 IP address formats Format
IP address
This is the simplest IP address format. You can add the IP address of your PC to the whitelist, for example, 100.*.*.123.
CIDR
- If your server is on a LAN and uses the CIDR, you can add a 32-bit egress IP address of the LAN with a specified number of bits for the network prefix.
- Requests from the same IP address are accepted if the network prefix is the same as the specified one.
- Select I have read and agree to the Privacy Statement and CodeArts Service Statement., and click OK.
