- What's New
- Function Overview
Getting Started
- Uploading Software Packages to Release Repos
- Uploading Components to Maven Repository
- Releasing/Obtaining a Maven Component via a Build Task
- Releasing/Obtaining an npm Component via a Build Task
- Releasing/Obtaining a Go Component via a Build Task
- Releasing/Obtaining a PyPI Component via a Build Task
- Uploading/Obtaining an RPM Component Using Linux Commands
- Uploading/Obtaining a Debian Component Using Linux Commands
User Guide
- CodeArts Artifact User Guide
- Release Repos 2.0
- Self-Hosted Repos 2.0
- Release Repos 1.0
- Self-Hosted Repos 1.0
- Whitelist for All Accounts
Best Practices
- CodeArts Artifact Best Practices
- Releasing Maven Components and Archiving to a Self-Hosted Repo
- Batch Migrating Maven/npm/PyPI Components to a Self-Hosted Repo
- API Reference
- Release Repo
Self-Hosted Repo
- How Do I Upload Snapshots to a Maven Repository?
- How Do I Pull Components from a Maven Repository?
- Can I Call Software Packages in Self-Hosted Repos During Local Builds?
- What Should I Do With Error Code 500 When Uploading Maven Package for a Gradle Build?
- Why Did the Dependency WAR or JAR Files Fail to Be Downloaded?
- Why Is Error 401 Returned When Uploading Maven Components to Self-Hosted Repos?
Editing a Component
You can search for, download, delete, favorite, and unfavorite private components.
Searching for a Component
- Go to the self-hosted repo page and click Advanced Search in the upper left corner of the page. The Advanced Search page is displayed.
- You can select the type of component to be searched for in the upper part of the page. By default, all types are selected. You can search for information using either of the following methods:
- The default file name mode is as follows:
- Enter the keyword of the file name in the search box, and click
to search for the component.
- In the search result list, click a file name to view the component details.
- Select Checksums mode.
- Click the drop-down list on the left of the search box and select Checksums (The default value is File Name).
- Or enter the MD5/SHA-1/SHA-256/SHA-512 checksum and click
to find the corresponding component.
Downloading a Component
- Go to the self-hosted repo page. In the left pane, locate the component to be downloaded, and click its name.
If there are too many repositories or components, you can search for the desired one by referring to Searching for a Component.
- Click Download on the right of the page.
Deleting a Component
- Go to the self-hosted repo page. In the left pane, locate the component to be deleted, and click its name.
- Click Delete on the right of the page.
- In the displayed dialog box, click Confirm.
Favoriting/Unfavoriting
- Go to the self-hosted repo page. In the left pane, locate the component to be favorited, and click its name.
- Click Favorite on the right of the page.
When the icon changes to
, click My favorites in the lower left corner of the page to view the list of favorited components. Click a value in the path column to go to the component details page.
