Updated on 2025-08-05 GMT+08:00
Accessing Release Repos
CodeArts Artifact was upgraded in March 2023. Inventory Release Repos and resources belonging to users who registered before this update are stored in the old Release Repos.
If you have existing repositories and resources, you can upload and manage software packages in the legacy Release Repos. After you create a project, Release Repos with the same project name is automatically generated in the new Release Repos.
  1. Click a project card to access the project, and choose Artifact > Release Repos from the menu bar.
  2. Click Old Repo in the lower left corner.
  3. View the existing file list of the current project. You can perform the following operations as required:
    No.
    Operation
    Switch project
    Click the project name drop-down list to switch the project to view the legacy Release Repos.
    2
    Upload
    Click Upload in the upper left corner of the list to manually upload local packages to Release Repos.
    The size of each file to upload cannot exceed 2 GB.
    You are advised not to upload files containing sensitive information such as plaintext accounts and passwords to the Release Repos.
    3
    Create folder
    Click More and select Create Folder in the upper right corner to create a folder on the current page.
    4
    Recycle bin
    Click More and select Recycle Bin in the upper right corner to access the recycle bin, where you can manage deleted packages or folders.
    5
    Edit
    Click in the Operation column to edit the package or folder.
    • Package: You can change the name and release version of the package. (The release version archived by CodeArts Build is the build sequence number by default.)
    • Folder: You can edit the folder name.
    6
    Download
    Click in the Operation column to download the package.
    7
    Delete
    • Click in the Operation column. In the displayed dialog box, click Remove to Recycle Bin to move the corresponding package or folder to the recycle bin, or click Clear to delete it permanently.
    • Select multiple packages or folders. In the displayed dialog box, click Remove to Recycle Bin to move them to the recycle bin, or click Clear to delete them permanently.
      Packages in the recycle bin still use space in Release Repos. The space will be freed up only after a package is permanently deleted from the recycle bin.
    8
    Search
    Enter a keyword (a folder or file name) in the search box above the list and click to search for the package whose name contains the keyword.
    9
    Change status
    After entering a level-1 folder, you can change the status of a level-2 folder by clicking the drop-down list in the Package Status column.
    The status can be Not Released or Released. A folder can change from Not Released to Released, but such a change is irreversible. If a folder is Released, the folder cannot be changed or edited (changing the folder name, changing the file name in the folder, uploading the folder, changing the version number, or creating a subfolder). You can only download or delete it.
    10
    New repo
    Click New Repo to return to the new version of Release Repos.
