Help Center/ CodeArts Artifact/ User Guide/ CodeArts Artifact User Guide
Updated on 2025-10-11 GMT+08:00
CodeArts Artifact assists developers in managing dependencies across different programming languages during development and builds. It stores binary artifacts and centralizes key delivery components. It supports popular package types like Maven and npm. CodeArts Artifact can seamlessly interconnect with local build tools and on-cloud CI/CD so that you can manage software package lifecycle to improve release quality and efficiency. It also provides features such as artifact package version control, granular permission management, and more.
CodeArts Artifact is a service provided within the CodeArts solution. For details about its role in the solution, see CodeArts Architecture.
Basic operation process of CodeArts Artifact
Table 1 Steps in using CodeArts Artifact
Step
Purchase CodeArts Artifact
Before using CodeArts Artifact, you need to first purchase CodeArts Artifact.
Access CodeArts Artifact
CodeArts Artifact provides two repository types: release repos and self-hosted repos. You can access either release repos or self-hosted repos as needed.
Upload packages
You can upload packages to release repos or self-hosted repos for further management and use.
Manage packages
You can manage packages by viewing, downloading, setting status, managing versions, and deleting them in release repos and self-hosted repos.
Use packages
You can use CodeArts Artifact to store packages during deployment and build. For details, see CodeArts Artifact Best Practices.
