Help Center/
Customer Engagement Center/
User Guide/
Agent Guide(AICC)/
OpenEye Help Document/
Installation Description/
Version Upgrade/
Windows Version Upgrade
Updated on 2025-01-23 GMT+08:00
Overview
Version upgrade requires uninstalling the original version and installing the new version.
You can perform the upgrade in either of the following ways:
- Overwrite upgrade: Overwrite the original OpenEye client, which retains the original configuration.
- Upgrade after uninstallation: Manually uninstall the original client and install the new version. You can choose whether to retain the original client configuration.
Overwrite Upgrade
- Double-click OpenEyeSetup.exe to install the program. An uninstallation prompt is displayed. Click OK to uninstall the OpenEye of the original version.
Figure 1 Uninstallation prompt
- Wait until the uninstallation is complete. After the uninstallation is complete, install the new version. For details, see Procedure.
Upgrade After Uninstallation
- Manually uninstall the OpenEye program of the original version.
You can choose either of the following ways as required:
- Click the Start button, go to , find the OpenEye application in the installed application list, and click Uninstall to manually uninstall it.
- Go to the OpenEye installation directory, for example, C:\Huawei\OpenEye. Double-click the uninstallation program
- Confirm the uninstallation and click OK.
Figure 2 Information confirmation
- When the uninstallation is complete, select Do you want to delete all user data? and click Finish.
Figure 3 Uninstalling the program
- Double-click OpenEyeSetup.exe to run the installation program. For details, see Common Installation.
Parent topic: Version Upgrade
