Help Center/
Customer Engagement Center/
User Guide/
Tenant Administrator Guide/
Managing Cases/
Case Handling/
Handling a Task
Updated on 2025-01-23 GMT+08:00
Handling a Task
- Sign in to the AICC, choose
to create a task. , and click a case. On the case details page, click the Task tab and click
Figure 1 Create task - Click
. The task is created successfully.
- Click the Task tab, enter a task name, and press Enter to search for the task.
- Click Advanced Search and set advanced search criteria to search for tasks.
Figure 2 Advanced Search
- Click a task. The task details page is displayed.
- On the task details page, click
to transfer the task or click
to edit the task.
- Click
to change the task status based on the current task handling status.
Parent topic: Case Handling
