Help Center/
      Customer Engagement Center/
        User Guide/
        Tenant Administrator Guide/
        Managing Cases/
        Getting Started/
      Handling Your First Case
        Updated on 2025-01-23 GMT+08:00
- Sign in to the AICC as a case handler.
You need to change the password upon the first sign-in. Set a new password as prompted and sign in again.
 - Choose .
 - Click the Todo tab and click a case. The case details page is displayed.
 - You can perform the following operations on a claimed case:
: Follow an important or urgent case.
: Send an email or SMS notification to urge the case owner to handle a case that is about to expire. The prerequisite is that case reminder notification has been configured. For details, see Configuring Case Reminder Notification.
: Upgrade the case level. After the upgrade, an upgrade flag is added to the case title.
: Suspend a case that does not need to be handled temporarily.
: Transfer the case to change the case owner.
: Cancel the case.
: Close the case.
: Restart the case.- Comment: Add comments when you handle the case.
 - Add Attachment: Add supplementary information for the case, for example, fault screenshots provided by the customer. The total size of attachments cannot exceed 5 MB, and the number of attachments cannot exceed 5. JPG, PNG, PDF, JPEG, GIF, DOC, and DOCX attachments are supported.
 - Create on the Case Task tab page: Create a task and trace the handling when the case needs to be handled based on department collaboration.
     Figure 1 Create task page
       Multiple tasks can be created for a case.
 - Associated Case tab page: View associated cases after merging cases. For details about how to merge cases, see Merging Cases.
 - Internal Record tab page: Only the case owner and tenant administrator have the permission to perform operations on this tab page. An internal record can contain a maximum of 20,000 characters. If an image needs to be added, click Add Attachment to upload it.
     Figure 2 Internal Record tab page
   Parent topic: Getting Started
