Help Center/
Customer Engagement Center/
User Guide/
Tenant Administrator Guide/
IVR Journey Analysis/
Warning Condition
Updated on 2025-01-23 GMT+08:00
Warning Condition
- You have the IVR Analysis > Service Pre-warning Condition Configuration menu permission.
- The IVR analysis and intelligent IVR features have been enabled for the tenant space.
- You have configured an SMS gateway or email gateway.
- Sign in to the AICC and choose IVR Analysis > Service Pre-warning Condition Configuration.
Figure 1 Service Pre-warning Configuration
- Set the chatbot and flow version. The options for the chatbot selection box are IVR flows and intelligent IVR flows. Select a version of the flow corresponding to the selected chatbot.
- Click New. The Creating a Service Pre-alarm Condition dialog box is displayed.
Figure 2 Creating a Service Pre-alarm Condition
- Chatbot Access Code: The options are common IVR flows and intelligent IVR flows in the tenant space.
- Version: IVR flow version.
- Statistical Indicators: The options are Direct Rate, Non Direct Rate, Hang Up Rate, Failure Rate, Rehear Rate, and Transfer-to-manual rate. For details about the KPIs, see KPI Description.
- Pre-warning condition: The options are absolute value and MoM Value. absolute value indicates the distance of a value from zero. MoM Value indicates the change in the current month's value compared with the value in the previous month.
- Warning level: The options are Low, Middle, and High.
- Pre-warning Validity Period: The options are Permanently valid and Specifies the validity period.
- Reminder Mode: The options are SMS and Email.
- Reminder object: You can select multiple employees in the tenant space to send notifications.
- Click Save to save the warning condition.
- If your chatbot has warning records that meet the warning condition, and the records have been collected by a scheduled task, alarm events are generated. (The scheduled task is executed every hour.)
- Click Edit to edit the warning condition again.
Parent topic: IVR Journey Analysis
