Version Comparison
A flow has only one release version by default, but can have multiple historical versions. The version comparison function is used to compare the traffic and business KPIs of a version with those of the previous version, analyze the impact of version changes on KPIs, and evaluate the effect of flow adjustment.
- You have the IVR Analysis > Flow Compare menu permission.
 - The IVR analysis and intelligent IVR features have been enabled for the tenant space.
 - The chatbot flow to be analyzed has an access code.
 - The chatbot flow to be analyzed has call records in the query time range.
 - The selected flow version has release time.
- Sign in to the AICC and choose IVR Analysis > Flow Compare.
 - Set the chatbot, flow version, and query time range and press Enter to compare the KPIs before and after the release.
    Figure 1 Flow Compare
     - Click
 in the upper right corner to customize the KPIs to be displayed.
    Figure 2 Indicator Setting
     - Click a node name link to go to the node overview page. For details, see Flow Analysis.
