Help Center/
Cognitive Engagement Center/
User Guide/
Tenant Administrator Guide/
Robot Management and Configuration Guide/
Large Language Model Service Zone/
LLM-based Application Services/
Building the LLM-based Intelligent Case Filling Service/
Configuring Case 2.0 Information/
Customized Case Field
Updated on 2025-01-23 GMT+08:00
- The Case 2.0 feature has been enabled for the tenant space.
- You have the Case Configuration permission.
- Sign in to the AICC and choose .
- Click Create. In the Create dialog box, set field parameters as required.
Figure 1 Create
- Click
- (Follow-up operation) Choose Config corresponding to a template. The new field is displayed under Custom Field. Drag the field to the Container area so that it is referenced by the template.
and click Figure 2 Configure Case Template
Parent topic: Configuring Case 2.0 Information
