Selecting a Model Type.
The following model types of the agent assistant are supported: Large Model, Combined Model, and Small Model, of which capabilities are in descending order. You can select a model based on cost and service requirements.
You have contacted the system administrator to enable the LLM Engine feature for the tenant.
- Sign in to the AICC as a tenant space administrator, choose , and click the System Settings tab.
- Enter EMOTIONRECOGNITIONWORKFLOWPARAMS in the search box and click
to view the parameter.
- Click Edit on the right of the parameter and select a model type.
Figure 1 Edit Sentiment Analysis Workflow Parameters page
- Model Type: Options are Large Model, Small Model, and Combined Model. A large language model has powerful sentiment analysis capabilities, but its cost is higher than that of a small language model. Select a model based on actual requirements.
- Confidence Threshold: Retain the default value.
- Click Save.
