Performing Dialog Tests
If you already have a large number of intelligent robots and need to frequently test whether these robots function properly, you can create dialog test cases, execute them in batches, and check whether functions are normal based on the results.
- Sign in to the AICC and choose .
 - Create a test case group.
- Click
, enter test case group information, and click
. The test case group is successfully created.
     Figure 1 Add Test Case Group
      - Alternatively, click Batch operation and choose Generate Case to generate a test case group in the Initialize state. Click
 to filter selected records.
     Figure 2 Generate Dialog Case
     Figure 3 Filter Selected Records
      The filtering function can be used only if the oifde.chatrecord.switch parameter in the configuration file is enabled.
 - Click
 - Create a test case.
- Click Manage corresponding to the new test case group. The Manage Test Case dialog box is displayed.
     Figure 4 Add Test Case
      - Click
 to create a test case. - After a test case is created, in the Manage Test Case dialog box, click Manage corresponding to the new test case, create call content information, and click
     Figure 5 Manage Case Details
 - Perform a dialog test.
- Return to the Dialog Test page, and click Execute in the Operation column on the right of the new case group to execute the entire case group. After the execution is successful, Status changes to Finish.
 - Select some case groups, click Batch operation, and choose Execute to execute the selected case groups in batches. After the execution is successful, Status changes to Finish.
Figure 6 Executing some case groups
   - In the Manage Test Case dialog box, select some test cases, click Batch operation, and choose Execute to execute the selected test cases in batches. After the execution is successful, Status changes to Success.
     Figure 7 Executing some test cases
 - View the execution result and export the test report.
- After executing a test case group, view the number of tested cases, number of passed cases, number of failed cases, and pass rate.
     Figure 8 Viewing the execution result
      - Select the test case group that has been executed and click
 to export the test report.
