Help Center/ Customer Engagement Center/ User Guide/ Tenant Administrator Guide/ Managing Cases/ Case 2.0 Operation Guide/ Administrator Guide/ Case Configuration
Updated on 2025-11-07 GMT+08:00
Case Configuration
- Case Status
You can customize case statuses on the Case Status page during case handling. - Advanced Case Status
- Customized Case Field
An enterprise can flexibly set fields based on the business scenario. - Case Template
A case template contains the information to be collected from cases and the display format of the information, including the format of the page displayed during case creation, modification, or query. You can define the fields to be displayed in the case template and the layout of the fields. - Case Content Template
- Work Calendar
- Case Type
To differentiate businesses, you can classify cases into different types, such as complaint or consultation cases. Different types of cases can be associated with different statuses to meet business requirements. - Case Assignment Rule
When creating a case, you can choose to automatically assign the case to an owner. The automatic assignment will be performed based on the automatic assignment rule set on the platform. Only one automatic assignment rule can take effect under a tenant. - Case SLA Rule
- Case Reminder
- Case Role
- Case Queue
- User Role
- Case Closure Reason
A tenant space administrator can set case closure reasons.
Parent topic: Administrator Guide
