Response Templates Returned to the Semantic Recognition Invoker
Response templates can be configured by the customer or configured by the business personnel based on the customer requirements. After a template is configured, the backend automatically reads the parameter information.
The JSON format of the response template PromptText in the second response diagram element in the information matching flow is fixed. Ensure that the referenced parameter name is the same as the variable name defined in the flow.
- Choose and click
next to the information matching flow. - Click the Response diagram element in the lower part to view the response template name.
- Choose .
- Click Edit next to the template described in 2.
- On the Edit Template page, modify the JSON content as required. Ensure that the parameter names in the JSON file are the same as the variable names defined in the information matching flow.
