Help Center/
Customer Engagement Center/
User Guide/
Inspector Guide/
Processing Manual Post-Event Inspections/
Handling Review Applications
Updated on 2025-01-23 GMT+08:00
- Choose .
- Set the search criteria and click Search to obtain the search result. Click Reset to clear the existing search criteria.
Figure 1 Reconsideration Management page
- Click Details in the Operation column to view the inspection details. If an inspection record is in Approved or Failed state, you can only view the result. If it is in Pending state, you can click Details to handle the review application.
Figure 2 Handling a review application
- Click Reject. In the dialog box that is displayed, enter the comments. The manual inspection result remains unchanged. If you modify the score or summary of an inspection item, click Submit, and then enter the comments, the manual inspection result of the record is updated.
Figure 3 Entering review comments
Parent topic: Processing Manual Post-Event Inspections
