Switching Between Voice and Video Calls
During a customer's call to the IVR, you can switch between voice and video calls.
Diagram Element
Parameter Description
The following figure shows the parameters of the Change Media diagram element.
The parameters are described as follows:
- Node Name: Enter a diagram element name.
- Media: Select a target media type. The options are Audio and Video.
Condition Branch Description
| Condition Branch | Description | Usage |
| Switching failure | Failure to switch from a voice call to a video call or from a video call to a voice call | Triggered upon a switching failure. |
Typical Application Scenario
Voice and video calls need to be switched between each other when businesses are handled for a customer. The corresponding media capabilities are used to intuitively display businesses.
