Subflow
This diagram element is used to configure subflows for implementing tasks. No diagram element can be configured after a subflow.
Diagram Element
Parameter Description
The following figure shows parameters of the subflow diagram element.
The parameters are described as follows:
- Node Name: diagram element name to be displayed, which is customized.
- Description: diagram element description, which is customized.
- Target Flow: name of a subflow to be entered. You can select a published subflow of the current tenant from the drop-down list.
- Target Node: flow node to be executed. After a node is selected, the subflow starts from it.
Typical Application Scenario
An independent task needs to be processed. Generally, some common operations of a certain type can be extracted to form a subflow, making it easy to be reused.
