Configuring a Flow Track
By adding a calling number and using the OpenEye to call a called route that has been associated with an IVR flow, you can view the track of the flow after the voice is transferred to the IVR, for example, the transition of each diagram element in the flow, for fault locating.
Flow Tracking is a common module. For details, see Viewing Flow Tracks.
