Managing Variables
Variables are used in dialog flows to store data generated during flow execution. Variables defined in a flow can be used only in this flow. If a variable is involved in multiple flows, you need to define the variable as a global variable. Global variables can be referenced by all flows. Global variables are used in flows. The format of a global variable is ${GLOBAL.ParamName}.
Some operations under the current menu are controlled by separate permissions. If related operation permissions are not configured, the corresponding operations are not supported. For details about the operation permissions that can be configured separately, see Table 1.
Adding a Global Variable
- Choose .
- Choose and click
. In the dialog box that is displayed, set Variable Name and Data Type, and click Save.
Figure 1 Create Variable page
For security purposes, set Encryption Type to Encrypted for storage and decrypted upon retrieval or Encrypted for storage and retrieval if the variable contains personal data, such as the customer ID card number.
- Click
to import a ZIP file in JSON format.
Figure 2 Import Variables page
- Click
to export variables.
Figure 3 Page for exporting variables
Modifying a Built-in Variable
- Choose .
- Choose and click the Built-in Variable tab.
- Click Edit in the Actions column of one of the following built-in variables and change the default value based on site requirements.
Table 1 Built-in variables Variable Name
Data Type
Value Range
Default Value
language
Use this variable to set the language of the tenant.
Character
- Chinese
- English
- Spanish
- Arabic
- Thai
- Portuguese
- French
Chinese
timezone
Use this variable to set the offset of the time zone in which the tenant resides.
Floating-point number
–12 to 12
None
channeltype
Use this variable to set the channel of the tenant.
Character
default
default
responsestyle
Use this variable to set the style of the tenant.
Character
default
default
ttsSpeed
Use this variable to set the TTS speech speed of the tenant.
Integer
–500 to 500
0
ttsVolume
Use this variable to set the TTS volume of the tenant.
Integer
0 to 100
50
ttsPitch
Use this variable to set the TTS fundamental frequency of the tenant.
Integer
–500 to 500
0
voiceName
Use this variable to set the TTS speaker of the tenant.
Character
- Graceful
- Mature
- Soft
- Sweet
- Natural
Graceful
- After the modification is complete, click
