Configuring Skill Queue Monitoring Groups
The AICC provides monitoring groups for skill queues. You can add skill queues to a monitoring group to monitor and report different BPOs or businesses (such as B2B and B2C).
- A common agent must have the skill menu permission and the permission to edit skill menus on the GUI and in batches.
- Permissions on operations under the current menu that require separate configuration have been configured. For details about the operation permissions that can be configured separately, see Table 1.
- Sign in to the AICC as a tenant administrator and choose .
- Choose . Click New to create a monitoring group. Figure 1 Creating a Monitoring Group page
Table 1 GUI elements on the Creating a Monitoring Group page Element
Type
Monitoring Group Name
Text box
Enter the name of the monitoring group.
Value range: a string of no more than 64 bytes
Organization Unit
Drop-down list
Add an OU for the skill group.
You can filter OUs by keyword.
You can click
to clear the field.If Organization Unit is left empty, select Unorganized.
Value options:
- Tenant administrator: All OUs under the current tenant are available.
- Common agent:
- If the tenant parameter Has the tenant enabled inter-organization data isolation enforcement is set to Yes, accessible OUs that have the read and write permissions are available.
- If the tenant parameter Has the tenant enabled inter-organization data isolation enforcement is set to No, Unorganized and all OUs are available.
Skill Queue
Drop-down list
Click
to select a skill queue.A monitoring group can contain a maximum of 500 skill queues.
- Click Save.
A maximum of 2,000 monitoring groups can be created for a tenant space.
