Updated on 2023-09-20 GMT+08:00
Survey
Diagram Element
Parameter Description
The following figure shows the parameters of the Questionnaire diagram element.
The parameters are described as follows:
  • Element Name: Enter a diagram element name. The value can be customized.
Typical Application Scenarios
The Questionnaire diagram element is used only when an automatic outbound call task needs to be associated with an IVR survey flow. After an intelligent outbound call task is started, if the IVR flow associated with the outbound call task contains the Questionnaire diagram element, the survey content specified for the outbound call task is played to the user.
