Updated on 2023-09-20 GMT+08:00
Configuring IVR Recording
You can configure IVR recording to enable or disable recording in common IVR call flows.
  1. Sign in to the AICC and choose Configuration Center > Flow Configuration > Intelligent IVR.
  2. Choose System Management > System Configuration > System Settings and edit the CCIVRRECORDFLAG parameter.
  3. Set Value to Enable to enable recording or Disable to disable recording.
  4. Log in to the OpenEye and dial the access code configured on the Called Route page. If you can hear the tone played by the chatbot, the call can be completed normally, and the recording file can be obtained from the storage device of the server, the configuration is successful.
    Figure 1 System parameter for configuring IVR recording
    Figure 2 Selecting Enable for the recording flag
