Updated on 2026-07-28 GMT+08:00
Advanced Origins
You can configure advanced origins to allow CDN to pull content from different origin servers based on different URL paths.
Differences Between Advanced and Basic Origin Servers
Basic origin: origin server configured when you add a domain name to CDN. It is the default address of origin pulls for user requests.
Advanced origin: origin server from which CDN pulls content when a user request URL matches the resource type or path rule of this server.
  • You can configure up to 20 rules.
  • You cannot configure advanced origins on the console for domain names with special configurations.
Precautions
  • When CDN pulls content, the origin server provider charges the bandwidth or traffic fees generated by the origin server. For example, the traffic generated when CDN pulls content from OBS is charged by OBS.
  • You cannot configure origin request headers for advanced origin servers.
  1. Log in to the CDN console.
  2. In the navigation pane, choose Domains.
  3. In the domain list, click the target domain name or click Configure in the Operation column.
  4. Click the Origin Settings tab.
  5. In the Advanced Origin area, click Edit.
  6. Click Add to add an advanced origin rule.
    Figure 1 Advanced origins
    Table 1 Parameter description
    URI Match Mode
    URIs can be matched by All files, File name extension, and Directory.
    URI Match Rule
    All files: All requested resources are pulled from the configured advanced origin server. Exercise caution when selecting this option.
    File name extension
    • All file types are supported.
    • Start with a period (.) and separate multiple extensions by semicolons (;).
    • Enter up to 20 file name extensions.
    • Enter up to 512 characters.
    • File name extensions are case-sensitive.
    Example: .JPG;.zip;.exe
    Directory: Start with a slash (/) and separate multiple directories by semicolons (;). Spaces are not allowed. Enter up to 20 directories and up to 512 characters.
    Example: /test/folder01;/test/folder02
    • If you have signed URLs using method B or C1 for the acceleration domain name, URIs cannot be matched by Directory.
    • If you have enabled Client Access URL Rewrite for the acceleration domain name, CDN will use the rewritten URL for origin pull. In this case, use the rewritten path to ensure a successful rule match.
    Type
    Select IP address, Domain name, or OBS bucket.
    Address
    IP address
    • Enter an IPv4 address.
    Domain name
    • Start with a letter or digit. Use only letters, digits, hyphens (-), and periods (.). Enter up to 255 characters.
    • Each label of a domain name (for example, *** in ***.***.com) can contain up to 63 characters.
    • Third-party public object storage buckets can be accessed using their domain names.
    OBS bucket
    • Only OBS buckets of the current account can be accessed.
    • To access OBS private buckets, allow CDN to read OBS private buckets. For details, see OBS Authorization.
    • You cannot add an OBS bucket if the domain name has special configuration.
    • You cannot select Domain name as the origin server type for a whole site acceleration domain name.
    HTTP Port
    Port for origin pull using HTTP.
    • The port number ranges from 1 to 65535. The default port is 80.
    • If Type is set to OBS bucket, this parameter cannot be modified.
    HTTPS Port
    Port for origin pull using HTTPS.
    • The port number ranges from 1 to 65535. The default port is 443.
    Origin Protocol
    Protocol used by CDN PoPs to pull content from the origin server.
    HTTP: CDN uses HTTP for origin pull.
    HTTPS: CDN uses HTTPS for origin pull. (Ensure that the origin server supports HTTPS access.)
    Same as user: The origin protocol is the same as the client access protocol. For example, if a client accesses CDN using HTTP, CDN also uses HTTP for origin pull.
    You cannot set the origin protocol for whole site acceleration domain names.
    Host Header
    Host information of the advanced origin. For details, see Modifying the Host Header.
    If no Host header is specified for an advanced origin server, the Host header from the highest-priority basic origin server will be used during origin pulls for all matching requests.
    OBS Pull Authentication
    Applies when an OBS bucket is used as an origin server. Enable this switch if access to the bucket requires authentication. In this way, CDN PoPs carry the authentication information during origin pull. If the information does not match the OBS bucket, origin pull fails.
    • Enabled by default for a private bucket
    • Disabled by default for a public bucket
    Priority
    The priority value ranges from 1 to 1,000. The larger the value, the higher the priority.
    Operation
    Delete: Delete the rule.
  7. Configure parameters and click OK.
Examples
Example: Assume that you have configured an advanced origin for domain name www.example01.com.
Configuration result: When a user requests an uncached JPG resource, CDN pulls the resource from the origin server www.example.com. CDN pulls other uncached resources from the basic origin server.
Helpful Links
Modifying the Full Domain Configuration to modify advanced origin settings
