Origin Response Timeout
If the content requested by a user is not cached on CDN PoPs, CDN pulls the content from the origin server. If the origin pull times out, origin pull fails. The default timeout interval is 30s.
The origin response timeout in this document refers to the timeout interval for loading data after a TCP connection is set up, excluding the connection setup time.
If the timeout interval is too short, origin pull may fail frequently due to unstable network connections. If the timeout interval is too long, failed requests may still occupy connections for a long time when the maximum number of connections to the origin server is reached. As a result, normal requests fail. You can adjust the timeout interval based on the service features and network status of your origin server to ensure normal origin pull.
Background
Origin response timeout is the interval for HTTP requests during origin pull. It measures the time taken to load data after a TCP connection is set up, excluding the time required to set up the TCP connection.
Precautions
To modify the origin response timeout interval for domain names with special configurations, submit a service ticket.
- Log in to the CDN console.
- In the navigation pane, choose .
- In the domain list, click the target domain name. The Overview page is displayed.
- In the full configuration directory, click the Origin Settings tab.
- In the Origin Response Timeout area, click
. Figure 1 Origin response timeout
- Enter the timeout interval and click OK.
Helpful Links
Modifying the Full Domain Configuration to modify origin response timeout settings
