- What's New
- Function Overview
Product Bulletin
- [January 23, 2025] CAs Suspend OV and EV SSL Certificate Approval and Issuance During the Spring Festival
- [December 24, 2024] CA Venders Suspend Certificate Issuance During Christmas and New Year's Day
- [October 28, 2024] Notice on Switching the DigiCert Root Certificate
- [July 29, 2024] Notice on DigiCert and GeoTrust SSL Certificate Price Changes
- [October 8, 2023] Validity Period Change of Test Certificates
- [April 17, 2023] Changing GeoTrust DV to RapidSSL DV
- [Feb 8, 2023] Notice on DigiCert Root Certificate Update
- [December 16, 2022] DigiCert and GeoTrust Suspend OV and EV Certificate Validation During Christmas Holidays
- [September 13, 2022] SSL Certificate Chains Embedded in Applications May Cause Communication Failures
- [July 25, 2022] Organization Unit (OU) Field Removed from SSL Certificates
- [March 23, 2022] SSL Certificate Manager Entry Will Be Changed on March 25, 2022
- [Product Notices] Huawei Cloud SCM Domain Ownership Verification Policy (File-based Verification) Changed on Nov 12, 2021
- [August 20, 2020] Notice on the Change of the Maximum Validity Period of SSL Certificates
- [August 14, 2020] Notice on Delaying Issuance of EV and EV Pro Certificates Due to the DigiCert System Failure
- [July 27, 2020] CAs Will No Longer Issue Two-Year SSL Certificates
- [July 27, 2020] Notice on Revocation of DV Certificates by CAs
- [July 19, 2020] DigiCert System Maintenance Notice
- [May 31, 2020] GlobalSign System Maintenance Notice
- [May 3, 2020] DigiCert System Maintenance Notice
- [April 26, 2020] Symantec Certificate Brand Change Notice
- Billing
- Getting Started
SSL Certificate Manager (SCM) User Guide
- About SCM and SSL Certificate Usage
- Purchasing an SSL Certificate
- Applying for an SSL Certificate
Installing an SSL Certificate
Installing an SSL Certificate on a Web Server
- Downloading an SSL Certificate
- Downloading a Root Certificate
- Installing an SSL Certificate on a Tomcat Server
- Installing an SSL Certificate on an Nginx Server
- Installing an SSL Certificate on an Apache Server
- Installing an SSL Certificate on an IIS Server
- Installing an SSL Certificate on a WebLogic Server
- Installing an SSL Certificate on a Resin Server
- Deploying an SSL Certificate to Other Huawei Cloud Products
Managing SSL Certificates
- Reissuing an SSL Certificate
- Unsubscribing from an SSL Certificate
- Renewing an SSL Certificate
- Revoking an SSL Certificate
- Re-applying for a Revoked SSL Certificate
- Deleting an SSL Certificate from CCM
- Uploading an External Certificate to SCM
- Adding an Additional Domain Name
- Withdrawing an SSL Certificate Application
- Canceling Authorization for Privacy Information
- Pushing an SSL Certificate to Other Cloud Services
- Viewing Details About an SSL Certificate
- Viewing the Application Progress
- CSRs
- Sharing
- Managing Tags
- Permissions Management
- Private Certificate Authority (PCA) User Guide
Best Practices
- CCM Best Practice Summary
- Best Practices for SSL Certificate Manager
- Best Practices for Private Certificate Management
API Reference
- Before You Start
- Calling APIs
- API Overview
- API Description
- Examples
Historical APIs
SCM APIs
- Querying the Certificate List
- Querying Details of a Certificate
- Modifying a Certificate
- Querying the Product Type of a Certificate
- Querying the Product Details of a Certificate
- Applying for a Certificate
- Verifying a CSR
- Saving Certificate Information
- Reading the Information Entered When Applying for a Certificate
- Canceling an Application
- Deleting a Certificate
- Uploading Authentication Information
- Downloading a Certificate
- Uploading a Certificate
- Revoking a Certificate
- Pushing a Certificate
- Querying Push Records
- Querying Domain Name Verification Information
SCM APIs
- Appendix
- Change History
- SDK Reference
Certificate Consulting
- What Are the Differences Between SSL Certificate Manager and Private Certificate Authority?
- Which Websites Require HTTPS?
- What Are the Differences Between HTTPS and HTTP?
- What Is a Public Key and a Private Key?
- What Are the Relationships Between a Public Key, Private Key, and Digital Certificate?
- Why Is a Non-Password-Protected Private Key Required?
- What Are Mainstream Formats of Digital Certificates?
- What Information Does an SSL Certificate Contain?
- Can I Use SSL Certificates for Other Regions, Accounts, or Platforms?
- Can I Use an Unused SSL Certificate Anytime I Want?
- Can SSL Certificates Be Upgraded?
- Does the SSL Certificate Have Restrictions on the Server Port?
- Why Is SCM Inaccessible or the Operation Button Grayed Out When I Access the SCM Console?
- Regions and AZs
SSL Certificate Application and Purchase
- SSL Certificate Selection
About Required Domain Name Details
- How Do I Enter a Domain Name for a Certificate When Applying for an SSL Certificate?
- What Are the Differences Between a Single-Domain Name, Multi-Domain Name, and Wildcard-Domain Name in SCM?
- What Is the Relationship Between a Domain Name and an SSL Certificate?
- What Domains Can Wildcard-Domain Certificates Support?
- What Domain Name Should I Use to Apply for an SSL Certificate?
- Can I Change the Primary Domain Name Associated with a Certificate?
- Does the Relationship Between the Primary Domain Name and Additional Domain Name Have Any Impact on Domain Names?
- How Do I Make a CSR File?
- What Are the Differences Between the CSR Generated by the System and the CSR Made by Yourself?
- How Do I Export a CSR File?
- Domain-related Concepts
- Problems Related to Domains
- About Required Information
Troubleshooting
- What Can I Do If I Encounter a Problem When Purchasing, Applying for, Installing, or Using a Free SSL Certificate?
- What Can I Do If the Submit Button Is Unavailable?
- Can I Change Certificate Information After I Submit a Certificate Application?
- What Can I Do If I Encounter a Problem During SSL Certificate Application?
- About Test Certificates
Domain Name Ownership Verification
- How Do I Verify Domain Ownership?
- How Do I Verify the Domain Ownership Manually by DNS?
- How Do I Perform Verification by File?
- How Do I Perform Verification by Email?
- How Do I Check Whether Domain Name Verification Takes Effect?
- How Can I Check Whether DNS Verification Takes Effect for Windows OSs?
- What Can I Do If Domain Ownership Verification Does Not Take Effect?
- How Do I Query a Domain Name Provider?
- How Do I Query and Verify the Email Address of the Domain Administrator?
- How Do I Use DNS to Verify Domains Not Hosted on Huawei Cloud?
- Why Does the SSL Certificate Remain in the Pending Domain Name Verification State (Application Progress Is 40%) After Domain Name Verification Is Complete?
- How Do I Change the Domain Name Verification Mode When the SSL Certificate Status Is Pending domain name verification?
- What Do I Do If DNS Verification for a DV Certificate Fails?
- How Long Does It Take to Approve an SSL Certificate?
- Why Does the Certificate Stay in the CA Verifying Status for a Long Time?
- What Can I Do After I Submit an SSL Certificate Application?
- How Do I Handle the Email or Phone Call from the CA?
- Do I Need to Get a Newly Purchased SSL Certificate Approved?
- What Can I Do When I Fail to Pass the Security Review?
- What Can I Do When a Message Indicating Approval Failure Due to Blank Main Domain Name Is Displayed?
SSL Certificate Download, Installation, and Use
- SSL Certificate Download
SSL Certificate Installation
- On Which Servers Can an SSL Certificate Be Deployed?
- How Do I Install an SSL Certificate on a Server?
- How Do I Check Whether the Deployed SSL Certificate Takes Effect?
- Is the Original SSL Certificate Still Available After a Server IP Address Is Changed?
- In Which Geographical Locations Can an SSL Certificate Be Used?
- How Do I Add an SSL Certificate to the Background of a Website Built by Baota?
- How Do I Solve Problems Related to SSL Certificate Installation or Use?
SSL Certificate Use
- How Do I Configure a Non-Huawei Cloud SSL Certificate for a Huawei Cloud Product?
- How Do I Apply an SSL Certificate to Other Huawei Cloud Services?
- Which Region Will a Certificate Be Deployed to When I Deploy an SSL Certificate in CCM to Other Cloud Product?
- Is HTTPS Automatically Enabled After an SSL Certificate Is Deployed to a Cloud Product?
- How Do I Solve the Problem That Occurs When I Use Certificates in WAF, ELB, or CDN?
- Why Is a Message Indicating that the Certificate Chain Is Incomplete Displayed When I Configure HTTPS on CDN?
- Why Is an Error Reported When I Deploy an SSL Certificate with an Uploaded CSR to WAF, ELB, or CDN?
- How Do I Use an SSL Certificate After It Is Issued?
- What Can I Do If My SSL Certificate Cannot Be Deployed to Other Services?
- Issues Related to SSL Certificate Uploading
- What Can I Do If Errors Are Reported When I Upload an SSL Certificate?
SSL Certificate Troubleshooting
- What Can I Do If the Browser Displays a Message Indicating that the SSL Certificate Is Untrusted?
- Why Does the Browser Still Consider the Website Insecure While the Website Has an SSL Certificate Deployed?
- Why Is My Website Inaccessible by Domain Name After an SSL Certificate Is Installed?
- Why Does the HTTPS Access Speed Become Slower After an SSL Certificate Is Installed?
- Why Does the Browser Prompt a Not Secure Warning to Visitors After I Configure an SSL Certificate for the Website?
- What Can I Do If the Browser Displays "Your Connection Is Not a Private Connection"?
- Will the Browser Prompt A Warning Indicating the Deployed SSL Certificate Is Not Secure?
Certificate Validity Period
- What Can I Do If My SSL Certificate Expired?
- How Long Is an SSL Certificate Valid?
- What Can I Do If an SSL Certificate Is About to Expire?
- How Long Does an SSL Certificate Take Effect After Being Purchased?
- Validity Periods and Replacement of the Current and New SSL Certificates
- How Can I Renew an SSL Certificate?
- How Do I Configure a Certificate Expiration Notification?
- Will Services Be Affected If an SSL Certificate Is Not Updated After It Expires?
- Validity Periods of Private Certificates
- How Long Will an Order Become Invalid If I Do Not Apply for a Certificate After Purchasing It?
- How Do I Know When My Certificate Expires?
- About Billing, Renewal, and Unsubscription
SSL Certificate Management
- What Are the Differences Between Revoking a Certificate and Deleting a Certificate?
- Can I Withdraw a Certificate Revocation or Deletion Application?
- How Do I Convert a Certificate into the PEM Format?
- How Do I Complete the Certificate File When Uploading a Certificate?
- How Do I Configure a Certificate Chain?
- Why Is the SSL Certificate Not Displayed in the Certificate List?
- How Long Does It Take to Revoke a Certificate?
- Troubleshooting
- About Certificate Use
- Videos
More Documents
- Overview of Private Certificate Application
- Private CA Management
- Applying for a Private Certificate
- Downloading a Private Certificate
Installing a Private Certificate
- Trusting a Private Root CA
- Installing a Private Certificate on a Client
Installing a Private Certificate on a Server
- Installing a Private Certificate on a Tomcat Server
- Installing a Private Certificate on an Nginx Server
- Installing a Private Certificate on an Apache Server
- Installing a Private Certificate on an IIS Server
- Installing a Private Certificate on a WebLogic Server
- Installing a Private Certificate on a Resin Server
- Revoking a Private Certificate
- Viewing Details of a Private Certificate
- Deleting a Private Certificate
- FAQs
- Change History
- API Reference (ME-Abu Dhabi Region)
Show all
Reissuing an SSL certificate is a process in which a user needs to obtain a new certificate to replace the original certificate when the SSL certificate is still valid. Generally, you need to re-issue the SSL certificate in the following scenarios:
- Key leakage or loss: If the key of a website is disclosed or lost, you are advised to issue a new SSL certificate to ensure website security.
- Changing the domain name: If the domain name of a website is changed, the original SSL certificate is no longer applicable. You need to issue a new SSL certificate to match the new domain name.
- Incorrect certificate configuration: If the configuration information (for example, the domain name or organization information) is incorrect when you apply for an SSL certificate, you need to re-issue the SSL certificate.
- The certificate is in the Issued state.
- The certificate is a single-domain or wildcard-domain certificate.
- Free certificates, multi-domain certificates, and revoked certificates cannot be reissued.
- An issued certificate can be reissued within a specified period. The period varies depending on domain type and CAs. The following describes the period given by some CAs:
- DigiCert and GeoTrust: 25 days.
- There is no limit on how many times you can apply for reissues of a single-domain or wildcard-domain certificate only when the reissue is requested within the specified period. This period varies depending on CAs.
- Click
in the upper left corner of the page and choose Security & Compliance > Cloud Certificate Management Service. The service console is displayed.
- In the navigation pane on the left, choose SSL Certificate Manager > SSL Certificates.
- In the Operation column of the target certificate, choose More > Reissue, as shown in the Figure 1.
If the reissue button disappears or the reissue failed, check the following items:
- Certificate status. The certificate you want to reissue must have been issued. If the certificate is not issued, it cannot be reissued.
- Certificate type. Free certificates and multi-domain certificates cannot be reissued.
- Certificate CA. If your certificate was issued by GlobalSign, a reissue can only be initiated within 5 days after the certificate was issued.
- Certificate CA. If your certificate was issued by DigiCert, GeoTrust, CFCA, TrustAsia, or vTrus, a reissue can only be initiated within 25 days after the certificate was issued.
- To change the domain name for a certificate, perform operations by referring to Table 1. You can also modify the company contact or authorizer information.
Figure 2 Reissuing a certificate
Table 1 Domain name parameters Parameter
Example Value
CSR
To obtain an SSL certificate, a Certificate Signing Request (CSR) file needs to be submitted to the CA for review. A CSR contains a public key and a distinguished name (DN). Typically, a CSR is generated by a web server. A pair of public and private keys are created along with the CSR.
Options:- System generated CSR: The system automatically generates a certificate private key. Once the certificate is issued, you can download your certificate and private key on the certificate management page.
- You manually generate a CSR file and paste the content of the CSR file into the text box. For more details, see How Do I Make a CSR File?
You are advised to select System generated CSR to avoid approval failure caused by incorrect content. For details about the differences between the two types of certificate request files, see What Are the Differences Between the CSR Generated by the System and the CSR Made by Yourself?
Domain Name
This parameter is displayed when you purchase a single-domain or wildcard-domain certificate.
- If you select Upload a CSR for CSR, the domain name is automatically parsed based on the CSR file. You do not need to manually enter the domain name.
- If you select System generated CSR for CSR, manually enter the domain name or wildcard domain to be associated with the certificate.
Single domain: If your domain is www.domain.com, enter www.domain.com for Domain Name.
Wildcard domain: If you have multiple domain names that are all the same level, for instance, test.huaweicloud.com, yun.huaweicloud.com, example.huaweicloud.com, and good.huaweicloud.com, you can use a wildcard to enter a single domain name that would include them all, in this case: *.huaweicloud.com.
www.domain.com
Domain Name Verification Method
In accordance with the CA specifications, after applying for a certificate, you need to work with the CA to verify ownership of the associated domain name. After your ownership of the domain name is verified by you and approved by the CA, the CA will issue the certificate.
Options:
- DNS: You need to verify the domain ownership by resolving a specific DNS record on the domain name management platform.
- Automatic DNS verification: The system automatically adds DNS records for verification.
If you have purchased DV (domain name) certificate, and you have registered a domain name on the Huawei Cloud platform and the domain name has been resolved by Huawei Cloud DNS, you can choose this verification method.
- Manual DNS verification: You need to go to the DNS service provider of the domain name to perform the verification.
- File: You need to create a specified file on the server to verify your ownership of the domain.
- Email: You can click the link and follow the directions in the email to verify ownership of the domain.
- DV (basic) certificates (GeoTrust entry-level SSL certificates and DigiCert free SSL certificates) are verified by DNS by default.
- After confirming that the entered information is correct, read through the Cloud Certificate Manager Statement, Privacy Statement, and the authorization statement, and check the box to agree to the disclaimer and statements
If the certificate is not being reviewed, you can cancel the authorization for privacy information. Once you revoke the authorization, the platform will no longer store your information. The contact name, phone number, email address, and organization details will be deleted. For more details, see Canceling Authorization for Privacy Information.
- Click Submit.
- After you submit the reissue application, the certificate status has changed to CA verifying (reissue).
- The CA will send an email to you within one to two working days to confirm the cancellation of the issued certificate. After you confirm the email, the CA will cancel the issued certificate and the certificate will enter the reissue process.
If you have modified the domain name or information about the company contact or authorizer, the certificate is in the Pending domain name verification status after the original certificate is canceled. The certificate can be reissued only when you complete Verifying Domain Name Ownership and Verifying the Organization (OV and EV) (required only for OV, OV Pro, EV, and EV Pro certificates).
