Help Center/ Cloud Container Engine/ User Guide/ Clusters/ Accessing a Cluster/ Using KooCLI and kubectl to Access a Cluster
Updated on 2026-09-21 GMT+08:00
CCE has integrated credential plugins into Huawei Cloud Koo Command Line Interface (KooCLI). kubectl can execute these plugins to obtain IAM credentials from users for cluster access. This eliminates the need to store static user certificates locally and enables precise audit tracing to specific users.
  • CCE cluster versions must be v1.29.15-r80, v1.30.14-r80, v1.31.14-r40, v1.32.13-r10, v1.33.10-r10, v1.34.6-r10, v1.35.3-r10, v1.36.1-r0, or later.
  • If private access is used, the client and the target cluster must be in the same VPC.
  • If public access is used, the target cluster must have an EIP bound. For details about how to bind an EIP, see Procedure.
    • Binding an EIP to an API server for Internet access can pose a risk to the cluster's security. To mitigate this risk, configure Advanced Anti-DDoS or API server access policies (Configuring Access Policies for an API Server) for the bound EIP.
    • Binding an EIP to an API server will cause the API server to restart briefly and update the kubeconfig certificate. Do not make any changes to the cluster during this period.
IAM federated users cannot access clusters using KooCLI and kubectl.
Step 1: Download kubectl
Before using kubectl to access a cluster, install kubectl on the client. Run the kubectl version command to check whether kubectl is installed. If it is installed, skip this step. This section uses Linux as an example to describe how to install and configure kubectl. For details, see Installing kubectl.
  1. Log in to your client and download kubectl. v1.35.0 is used as an example version. Replace it with your target version as needed.
    cd /home
    curl -LO https://dl.k8s.io/release/v1.35.0/bin/linux/amd64/kubectl
  2. Run the following command to install kubectl:
    chmod +x kubectl
    mv -f kubectl /usr/local/bin
  3. Run the following command to check whether kubectl has been installed:
    kubectl version
    If information similar to the following is displayed, kubectl has been installed:
    Client Version: xxx
    Kustomize Version: xxx
    Server Version: xxx
Step 2: Install KooCLI
Run hcloud version to check whether KooCLI is installed. If KooCLI is installed and the version is 7.2.12 or later, skip this step. If KooCLI is installed but the version does not meet the requirements, reinstall KooCLI.
For details about how to install KooCLI, see Getting Started.
Step 3: Configure KooCLI
KooCLI supports multiple configuration methods. This section describes two common methods. For more configuration options, see the KooCLI Documentation.
Method 1: Using a permanent AK/SK (applicable to most users)
Run the following command to configure KooCLI:
hcloud configure set --cli-profile=${profileName} --cli-region=${region} --cli-mode=AKSK --cli-access-key=${AK} --cli-secret-key=${SK}
Check whether the configuration is successful.
hcloud configure show --cli-profile=${profileName}
${profileName} indicates the custom KooCLI profile name. ${region} indicates the region ID. ${AK} indicates the Access Key ID from the permanent AK/SK pair. ${SK} indicates the Secret Access Key from the permanent AK/SK pair.
Method 2: Using SSO login (for IAM Identity Center users)
# Step 1
hcloud configure set --cli-mode=SSO --cli-profile=${profileName} --cli-sso-start-url=${sso_start_url} --cli-sso-region=${region} --cli-region=${region}
# Step 2
hcloud configure sso --cli-profile=${profileName}
${profileName} indicates the custom KooCLI profile name. ${region} indicates the region ID. ${sso_start_url} indicates the IAM Identity Center URL. For details, see the documentation.
hcloud configure sso is an interactive command. Follow the prompts to complete the SSO login.
KooCLI saves the configuration locally. Sensitive information, such as authentication credentials (AK/SK), is encrypted at rest.
Step 4: Use KooCLI to Generate kubeconfig
  1. Run the following command to view the clusters of the current user:
    hcloud cce list-cluster
    After the command is executed, output similar to the following is displayed:
    UID                                      NAME                                     VERSION         STATUS          ACCESS
    9e07d2cf-02db-11ef-acea-0255ac100b08     cce-cluster-1                            v1.28           Unavailable     Internal
    6a533499-e9e8-11f0-b1d8-0255ac1001b8     cce-cluster-2                            v1.33           Available       Internal/External
  2. Select the target cluster and run the following command to generate the kubeconfig file:
    # Private access
    hcloud cce update-kubeconfig --cluster-id=${clusterID}
    # Public access (supported only when the cluster has an EIP bound)
    hcloud cce update-kubeconfig --cluster-id=${clusterID} --external=true
    $(clusterID) indicates the cluster ID. After the kubeconfig file is generated, output similar to the following is displayed:
    Successfully generated/updated kubeconfig at: /root/.kube/config
    Context: *****
    Cluster: *****
    The table below lists the configurable parameters for hcloud cce update-kubeconfig. You can also run hcloud cce update-kubeconfig --help to view them.
    --output
    Path for storing the generated kubeconfig file. The default value is ~/.kube/config.
    --external
    Whether to access the cluster through a public network. The default value is false.
    --external-tls-verify
    Whether to enable two-way authentication when accessing a cluster through a public network. The default value is false.
    --ak
    Access Key ID, which is obtained from the KooCLI configuration by default.
    --sk
    Secret Access Key, which is obtained from the KooCLI configuration by default.
    --security-token
    Security token, which is obtained from the KooCLI configuration by default.
    --region
    Region ID, which is obtained from the KooCLI configuration by default.
    --project-id
    Project ID, which is obtained from the KooCLI configuration by default.
    --user-name
    Username in the generated kubeconfig file. The default value is {cluster-name}-user.
    --context-name
    Context name in the generated kubeconfig file. The default value is {cluster-name}-context.
    --cce-endpoint
    Domain name for accessing CCE. The default value is https://cce.{region}.myhuaweicloud.com.
  3. Run the following command to check whether the cluster can be accessed using kubectl:
    kubectl cluster-info
    If the following information is displayed, the cluster can be accessed using kubectl:
    Kubernetes control plane is running at https://xx.xx.xx.xx:5443 CoreDNS is running at https://xx.xx.xx.xx:5443/api/v1/namespaces/kube-system/services/coredns:dns/proxy
    To further debug and diagnose cluster problems, use 'kubectl cluster-info dump'.
    • When you use kubectl with credential plugins to access a cluster, the Kubernetes permissions are the same as those granted to the IAM user on the CCE console.
    • In Linux, if the KUBECONFIG environment variable is set, kubectl loads that configuration instead of $home/.kube/config.
    • When you access a cluster via a public network, two-way authentication is disabled by default. To enable it, set external-tls-verify=true in update-kubeconfig.
