Help Center/ Cloud Container Engine/ User Guide/ Storage/ OBS/ Using a Temporary Custom Access Key (AK/SK) to Mount an OBS Volume
Updated on 2026-09-21 GMT+08:00
In containerized application deployment, mounting an OBS bucket into a container still requires a permanent AK/SK. Because these credentials never expire, they broaden the blast radius of any leak and clash with the least-privilege policies that security-focused enterprises now enforce. The container-storage add-on (CCE Container Storage (Everest)) eliminates the need for permanent AK/SKs by generating a short-lived, custom AK/SK each time an OBS volume is mounted. Unlike the permanent AK/SKs held by IAM users, these credentials are created on demand, expire in 15 minutes to 24 hours, and are then automatically deleted, eliminating the long-term risk of a leaked key.
Notes and Constraints
  • When an OBS volume is mounted using a temporary custom AK/SK, you must periodically refresh that credential before it expires. Otherwise, service containers will not be able to access the mounted OBS volume.
  • Temporary custom AK/SKs cannot be configured for secure containers.
  • Once an OBS volume has been mounted with a temporary AK/SK, the credential type cannot be switched to a permanent one. In this case, dynamic key replacement is not supported.
  • The temporary AK/SK inherits the exact OBS read/write permissions of the IAM user who requested it, so that user must already hold those rights.
Creating a Secret Using Access Keys
  1. Obtain temporary access keys (AK/SK and STS token). For details, see Temporary Access Key (for Federated Users).
  2. Encode each credential in Base64. (Assume that the AK is xxx, the SK is yyy, and the STS token is zzz.)
    echo -n xxx|base64
    echo -n yyy|base64
    echo -n zzz|base64 -w 0
    Record the encoded AK/SK and STS token.
  3. Create a YAML file, for example test-user.yaml, to hold the secret.
    apiVersion: v1
    data:
      access.key: WE5WWVhVNU*****
      secret.key: Nnk4emJyZ0*****
      security.token: Adfaf*****
    kind: Secret
      namespace: default
      labels:
        secret.kubernetes.io/used-by: csi
    type: cfe/secure-opaque
    The parameters are as follows.
    access.key
    The Base64-encoded AK
    secret.key
    The Base64-encoded SK
    security.token
    The Base64-encoded STS token
    name
    The secret name
    namespace
    The namespace of the secret
    The label required so the console can use this secret when provisioning an OBS PV/PVC.
    type
    The secret type. The value must be cfe/secure-opaque.
    When this type is used, user input is encrypted automatically.
  4. Create the secret.
    kubectl create -f test-user.yaml
Mounting a Secret to an OBS Volume
The method of mounting an OBS volume varies depending on how the volume was created.
After a secret is created using the AK/SK, you can associate the secret with the PV to be created and then use the AK/SK in the secret to mount an OBS volume.
  1. Log in to the OBS console, create an OBS bucket, and record the bucket name and StorageClass. The parallel file system is used as an example.
  2. Create a YAML file for the PV, for example, pv-example.yaml.
    apiVersion: v1
    kind: PersistentVolume
      annotations:
        pv.kubernetes.io/provisioned-by: everest-csi-provisioner
      accessModes:
      - ReadWriteMany
      capacity:
        storage: 1Gi
      csi:
        nodePublishSecretRef:
          namespace: default
        driver: obs.csi.everest.io
        fsType: obsfs
        volumeAttributes:
          everest.io/obs-volume-type: STANDARD
          everest.io/region: ap-southeast-1
          storage.kubernetes.io/csiProvisionerIdentity: everest-csi-provisioner
        volumeHandle: obs-normal-static-pv
      persistentVolumeReclaimPolicy: Delete
      storageClassName: csi-obs
    Secret specified during the mounting.
    • name: name of the secret
    • namespace: namespace of the secret
    fsType
    File type, which can be s3fs or obsfs. If the value is s3fs, an OBS bucket is created. If the value is obsfs, an OBS parallel file system is created.
    volumeHandle
    OBS volume name.
  3. Create a PV.
    kubectl create -f pv-example.yaml
    After a PV is created, you can create a PVC and associate it with the PV.
  4. Create a YAML file for the PVC, for example, pvc-example.yaml.
    Example YAML file for the PVC:
    apiVersion: v1
    kind: PersistentVolumeClaim
      annotations:
        csi.storage.k8s.io/node-publish-secret-name: test-user
        csi.storage.k8s.io/node-publish-secret-namespace: default
        volume.beta.kubernetes.io/storage-provisioner: everest-csi-provisioner
        csi.storage.k8s.io/fstype: obsfs
      namespace: default
      accessModes:
      - ReadWriteMany
      resources:
        requests:
          storage: 1Gi
      volumeName: pv-obs-example
    Secret name
    Namespace of the secret
  5. Create a PVC.
    kubectl create -f pvc-example.yaml
    After the PVC is created, you can create a workload and associate it with the PVC to create volumes.
When dynamically creating an OBS volume, you can use the following method to specify a secret:
  1. Create a YAML file for the PVC, for example, pvc-example.yaml.
    apiVersion: v1
      annotations:
      namespace: default
      accessModes:
      - ReadWriteMany
      resources:
        requests:
          storage: 1Gi
    Secret name
  2. Create a PVC.
Verification
You can use a secret of an IAM user to mount an OBS volume. Assume that a workload named obs-secret is created, the mount path in the container is /temp, and the IAM user has the CCE ReadOnlyAccess and Tenant Guest permissions.
  1. Query the name of the workload pod.
    kubectl get pod | grep obs-secret
    Expected outputs:
    obs-secret-5cd558f76f-vxslv          1/1     Running   0          3m22s
  2. Query the objects in the mount path. In this example, the query is successful.
    kubectl exec obs-secret-5cd558f76f-vxslv -- ls -l /temp/
  3. Write data into the mount path. In this example, the write operation failed.
    kubectl exec obs-secret-5cd558f76f-vxslv -- touch /temp/test
    Expected outputs:
    touch: setting times of '/temp/test': No such file or directory
    command terminated with exit code 1
  4. Set the read/write permissions for the IAM user who mounted the OBS volume by referring to the bucket policy configuration.
  5. Write data into the mount path again. In this example, the write operation succeeded.
  6. Check the mount path in the container to see whether the data is successfully written.
    Expected outputs:
    -rwxrwxrwx 1 root root 0 Jun  7 01:52 test
