Configuring EVS Mount Options
Mount options are parameters passed to the kernel during file system mounting. They control the access mode, performance optimization, and security policies of storage devices (such as EVS, SFS, and OBS). CCE allows you to configure mount options in PVs and StorageClasses.
- Configuring mount options in a PV applies only to that specific PV. This method is used when custom mount parameters are needed for a particular storage volume.
- Configuring mount options in a StorageClass applies to all PVs created using that StorageClass. This method is used for centrally configuring mount options for EVS disks.
The CCE Container Storage (Everest) version must be 2.4.153 or later. This add-on identifies the mount options and transfers them to the underlying storage resources. The parameter settings take effect only if the underlying storage resources support the specified options.
- Mount options cannot be configured for secure containers.
- EVS mount options cannot be configured for workloads running on Huawei Cloud EulerOS 1.1 or CentOS 7.6 nodes.
EVS Mount Options
CCE supports the mount options listed in the following table.
| Parameter | Value | Description |
| noatime/strictatime/relatime | Blank | Specify how file access time (atime) is updated. You can choose one of the following options:
Configuring Mount Options
You can configure mount options using one of the following methods.
You can use mountOptions to configure mount options in a PV. This configuration applies only to that specific PV. For details about mountOptions, see EVS Mount Options.
- Use kubectl to access the cluster. For details, see Accessing a Cluster Using kubectl.
- Configure mount options in a PV. Example:
apiVersion: v1 kind: PersistentVolume metadata: annotations: pv.kubernetes.io/provisioned-by: everest-csi-provisioner name: pv-disk # PV name labels: failure-domain.beta.kubernetes.io/region: <your_region> # Region of the node where the application is to be deployed failure-domain.beta.kubernetes.io/zone: <your_zone> # AZ of the node where the application is to be deployed spec: accessModes: - ReadWriteOnce capacity: storage: 10Gi # Storage capacity csi: driver: disk.csi.everest.io fsType: ext4 volumeHandle: {your_volume_id} # EVS volume ID volumeAttributes: storage.kubernetes.io/csiProvisionerIdentity: everest-csi-provisioner everest.io/disk-mode: SCSI everest.io/disk-volume-type: SATA everest.io/enterprise-project-id: '0' # Enterprise project ID. 0 indicates the default enterprise project. persistentVolumeReclaimPolicy: Retain storageClassName: csi-disk mountOptions: # Mount options - strictatime - After creating a PV, you can create a PVC, bind it to the PV, and mount the PV to the containers in the workload. For details, see Using an Existing EVS Disk Through a Static PV.
- Check whether the mount options are effective. In this example, the PVC is mounted to a workload using the nginx:latest image, with the mount path /testdir in the container. To verify the settings, do as follows:
- Check the name of the pod to which the PVC has been mounted. In this example, the workload name is web-disk.
kubectl get pod | grep web-diskInformation similar to the following is displayed:
web-disk-xxx 1/1 Running 0 23m
- Run the following command to access the pod:
kubectl exec -it web-disk-xxx -- bash
- Run the following command to access the mount path and obtain a test file:
cd /testdir echo 'ok' > testfile
- Run the command repeatedly and check the Access value in the output. If the Access value changes, the strictatime mount option is effective.
stat testfile && cat testfile > /dev/null
You can also use mountOptions to configure mount options in a StorageClass. This configuration applies to all PVs created using this StorageClass. For details about mountOptions, see EVS Mount Options. For more information about StorageClasses, see Customizing a StorageClass.
- Create a custom StorageClass. Example:
allowVolumeExpansion: true apiVersion: storage.k8s.io/v1 kind: StorageClass metadata: name: csi-disk-01 # StorageClass name mountOptions: # Mount options - strictatime parameters: csi.storage.k8s.io/csi-driver-name: disk.csi.everest.io csi.storage.k8s.io/fstype: ext4 everest.io/disk-volume-type: SAS everest.io/passthrough: "true" provisioner: everest-csi-provisioner reclaimPolicy: Delete volumeBindingMode: Immediate
- After the StorageClass is configured, you can use it to create a PVC. By default, dynamically created PVs inherit the mount options configured in the StorageClass. For details, see Using an EVS Disk Through a Dynamic PV.
