Workload Diagnosis
Based on previous O&M experience, load faults usually occur frequently, and handling these faults is time-consuming. To improve O&M efficiency, CCE introduces single-pod diagnosis to help O&M teams locate and rectify faults more efficiently.
The diagnosis tool uses Kubernetes native APIs, Kubernetes events, logs, and metrics to comprehensively analyze and determine problems and provide specific rectification suggestions. This comprehensive diagnosis method not only improves the accuracy of fault locating, but also significantly reduces the workload of O&M personnel, thereby improving the overall O&M efficiency.
- You have obtained resource permissions.
- The cluster version is later than v1.17.
- The cluster is in the Running state.
Selecting a Pod for Diagnosis
Only the latest 500 pod diagnosis records are retained.
- In the navigation pane, choose Health Center. Then, click the Pods tab.
- On the displayed tab, click Start Diagnosis. Then, select the pod to be diagnosed and click OK. Figure 1 Start Diagnosis
- After the diagnosis is complete, click View Details to view the diagnosis result. Figure 2 Diagnosis completed
Figure 3 Viewing the diagnosis result
