Cost Insights for a Region
Updated on 2024-11-12 GMT+08:00
Cost Insights for a region provides enterprise management personnel with an overall analysis report of container costs in that region. From the perspective of cloud native, enterprise management personnel can flexibly organize costs. Costs can be allocated to departments by cluster or namespace to generate department cost analysis reports. In addition, cost reports can be exported.
  • Cost Insights has been enabled.
  • Processing bills takes some time. After Cost Insights is enabled, there is about two days delay before you can view your costs.
  • Cloud Native Cluster Monitoring must run normally to ensure accurate data displays of namespaces, workloads, and node pools on the Cost Insights page.
Access Management
  1. Log in to the CCE console. In the navigation pane, choose Cloud Native Cost Governance.
    Figure 1 Cloud Native Cost Governance
  2. Click Connection Management to view the cluster connection status.
    Figure 2 Cluster connection
  3. Select the clusters that are not connected to Cloud Native Cost Governance and click Batch Connect. After Cloud Native Cost Governance is enabled, you can view the cluster connection status in the list. If your cluster is connected to Cloud Native Cost Governance for the first time, you need to wait for two days before viewing your costs.
    Figure 3 Batch connection
    Figure 4 Cluster connection management
Department Management
    Figure 5 Cloud Native Cost Governance
  2. Click Department Management to view the department configurations.
    Figure 6 Viewing the department configurations
  3. Click Edit Department to modify the custom department configurations.
    Figure 7 Modifying the department configurations
  4. Click Next to modify the percentages of shared costs allocated to departments.
    Figure 8 Modifying shared costs allocation
  5. Click Submit. The configurations are displayed on the department management page.
    Figure 9 Submitting the modification
  6. Close the department management page and view cost analysis reports in Department Cost Analysis.
    Figure 10 Viewing cost analysis reports
Using Cost Insights
After Cloud Native Cost Governance is enabled, go to the Cost Insights page to view the annual, quarterly, or monthly cost analysis reports of connected clusters.
Figure 11 Viewing the cost status
Table 1 Functions on the Cost Insights page
Report
Year-to-date costs/Last year same-period costs/YoY change
Annually
Year-to-date costs: costs generated from the start of the current year to the date of the most recent bill
Last year same-period costs: costs generated during the same period in the last year
YoY change: (Year-to-date costs – Last year same-period costs)/Last year same-period costs
Forecasted year-end costs/Last year same-period costs/YoY change
Annually
Forecasted year-end costs: estimated total costs by the end of the current year
Last year same-period costs: costs generated in last year
YoY change: (Forecasted year-end costs – Last year same-period costs)/Last year same-period costs
Quarter-to-date costs/Last quarter same-period costs/QoQ change
Quarterly
Quarter-to-date costs: costs generated from the start of the current quarter to the date of the most recent bill
Last quarter same-period costs: costs generated during the same period in the last quarter
QoQ change: (Quarter-to-date costs – Last quarter same-period costs)/Last quarter same-period costs
Forecasted quarter-end costs/Last quarter same-period costs/QoQ change
Quarterly
Forecasted quarter-end costs: estimated total costs by the end of the current quarter
Last quarter same-period costs: costs generated in last quarter
QoQ change: (Forecasted quarter-end costs – Last quarter same-period costs)/Last quarter same-period costs
Month-to-date costs/Last month same-period costs/MoM change
Monthly
Month-to-date costs: costs generated from the start of the current month to the date of the most recent bill
Last month same-period costs: costs generated during the same period in the last month
MoM change: (Month-to-date costs – Last month same-period costs)/Last month same-period costs
Forecasted month-end costs/Last month same-period costs/MoM change
Monthly
Forecasted month-end costs: estimated total costs by the end of the current month
Last month same-period costs: costs generated in last month
MoM change: (Forecasted month-end costs – Last month same-period costs)/Last month same-period costs
Changes in Total Costs
Annual, quarterly, and monthly
Cost details of the current year, quarter, and month, as well as cost changes compared with the last year, quarter, and month
View department cost analysis reports in Department Cost Analysis.
Figure 12 Viewing department cost analysis reports
Table 2 Parameters in Department Cost Details
Report
Department Name
Department name you set.
YTD Costs
Annually
Costs generated from the start of the current year to the date of the most recent bill
Last Year Same-Period Costs
Annually
Costs generated during the same period in the last year
Last Year Total Costs
Annually
Costs generated in last year
YoY Cost Increase
Annually
YoY Cost Increase (%)
Annually
Current Year CPU Costs
Annually
CPU costs generated from the start of the current year to the date of the most recent bill
CPU Costs/Current Year Total Department Costs
Annually
Current year CPU costs/Year-to-date costs (department costs)
YoY CPU Cost Increase
Annually
Current year CPU costs – Last year same-period CPU costs
QTD Costs
Quarterly
Costs generated from the start of the current quarter to the date of the most recent bill
Last Quarter Same-Period Costs
Quarterly
Costs generated during the same period in the last quarter
Last Quarter Total Costs
Quarterly
Costs generated in last quarter
QoQ Cost Increase
Quarterly
QoQ Cost Increase (%)
Quarterly
Current Quarter CPU Costs
Quarterly
CPU costs generated from the start of the current quarter to the date of the most recent bill
CPU Costs/Current Quarter Total Department Costs
Quarterly
Current quarter CPU costs/Quarter-to-date costs (department costs)
QoQ CPU Cost Increase
Quarterly
Current quarter CPU costs – Last quarter same-period CPU costs
MTD Costs
Monthly
Costs generated from the start of the current month to the date of the most recent bill
Last Month Same-Period Costs
Monthly
Costs generated during the same period in the last month
Last Month Total Costs
Monthly
Costs generated in last month.
MoM Cost Increase
Monthly
MoM Cost Increase (%)
Monthly
Current Month CPU Costs
Monthly
CPU costs generated from the start of the current month to the date of the most recent bill
CPU Costs/Current Month Total Department Costs
Monthly
Current month CPU costs/Month-to-date costs (department costs)
MoM CPU Cost Increase
Monthly
Current month CPU costs – Last-month same-period CPU costs
