Monitoring Metrics of NGINX Ingress Controller
You can use Prometheus and Grafana to observe the metrics of NGINX Ingress Controller.
The following uses Prometheus as an example to describe how to view the metrics of NGINX Ingress Controller of a cluster.
- Accessing Prometheus
(Optional) Bind a LoadBalancer Service to Prometheus so that Prometheus can be accessed from external networks.
- Monitoring Metrics of NGINX Ingress Controller
Enable metric collection for NGINX Ingress Controller so that NGINX Ingress Controller metrics are automatically reported.
- The cloud native cluster monitoring add-on 3.9.5 or later has been installed in the cluster. For details about this add-on, see Cloud Native Cluster Monitoring.
- NGINX Ingress Controller 2.5.4 or later has been installed in the cluster, and metric collection has been enabled. For details about this add-on, see NGINX Ingress Controller.
After the cloud native cluster monitoring add-on is installed, you can deploy workloads and Services. The Prometheus server will be deployed as a StatefulSet in the monitoring namespace.
You can create a public network LoadBalancer Service so that Prometheus can be accessed from external networks.
- Log in to the CCE console and click the name of the cluster with Prometheus installed to access the cluster console. In the navigation pane, choose Services & Ingresses.
- Click Create from YAML in the upper right corner to create a public network LoadBalancer Service.
apiVersion: v1 kind: Service metadata: name: prom-lb # Service name, which is customizable. namespace: monitoring labels: app: prometheus component: server annotations: kubernetes.io/elb.id: 038ff*** # Replace it with the ID of the public network load balancer in the VPC that the cluster belongs to. spec: ports: - name: cce-service-0 protocol: TCP port: 88 # Service port, which is customizable. targetPort: 9090 # Default Prometheus port. Retain the default value. selector: # The label selector can be adjusted based on the label of a Prometheus server instance. app.kubernetes.io/name: prometheus prometheus: server type: LoadBalancer - After the Service is created, enter {public-IP-address-of-the-load-balancer}:{Service-port} in the address box of the browser to access Prometheus.
Figure 1 Accessing Prometheus
- Choose Status > Targets to view the targets monitored by Prometheus.
Figure 2 Viewing monitored targets
Log in to Prometheus and click Graph to view the metrics of NGINX Ingress Controller.
Metric |
Type |
Description |
nginx_ingress_controller_bytes_sent |
Basic metric |
Number of bytes sent to the client |
nginx_ingress_controller_connect_duration_seconds |
Basic metric |
Duration for connecting to the upstream server |
nginx_ingress_controller_header_duration_seconds |
Basic metric |
Time required for receiving the first header from the upstream server |
nginx_ingress_controller_ingress_upstream_latency_seconds |
Basic metric |
Upstream service latency |
nginx_ingress_controller_request_duration_seconds |
Basic metric |
Time required for processing a request, in milliseconds |
nginx_ingress_controller_request_size |
Basic metric |
Length of a request, including the request line, header, and body |
nginx_ingress_controller_requests |
Basic metric |
Total number of client requests |
nginx_ingress_controller_response_duration_seconds |
Basic metric |
Time required for receiving the response from the upstream server |
nginx_ingress_controller_response_size |
Basic metric |
Length of a response, including the request line, header, and request body |
nginx_ingress_controller_nginx_process_connections |
Basic metric |
Number of client connections in the {active, reading, writing, or waiting} state |
nginx_ingress_controller_nginx_process_connections_total |
Basic metric |
Total number of connections in the {accepted or handled} state |
nginx_ingress_controller_nginx_process_cpu_seconds_total |
Basic metric |
CPU usage, in seconds |
nginx_ingress_controller_nginx_process_num_procs |
Basic metric |
Number of processes |
nginx_ingress_controller_nginx_process_oldest_start_time_seconds |
Basic metric |
Start time, in seconds elapsed since 00:00:00 on January 1, 1970 |
nginx_ingress_controller_nginx_process_read_bytes_total |
Basic metric |
Number of bytes read |
nginx_ingress_controller_nginx_process_requests_total |
Basic metric |
nginx_ingress_controller_nginx_process_resident_memory_bytes |
Basic metric |
Number of bytes of resident memory in use |
nginx_ingress_controller_nginx_process_virtual_memory_bytes |
Basic metric |
Number of bytes of virtual memory in use |
nginx_ingress_controller_nginx_process_write_bytes_total |
Basic metric |
Number of bytes written |
nginx_ingress_controller_build_info |
Basic metric |
A metric with a constant '1' labeled with information about the build |
nginx_ingress_controller_check_success |
Basic metric |
Cumulative count of syntax check operations of NGINX Ingress Controller |
nginx_ingress_controller_config_hash |
Basic metric |
Hash value of running NGINX Ingress Controller |
nginx_ingress_controller_config_last_reload_successful |
Basic metric |
Whether the last configuration reload attempt was successful |
nginx_ingress_controller_config_last_reload_successful_timestamp_seconds |
Basic metric |
Timestamp of the last successful configuration reload |
nginx_ingress_controller_ssl_certificate_info |
Basic metric |
All labels associated with a certificate |
nginx_ingress_controller_success |
Basic metric |
Cumulative count of reload operations of NGINX Ingress Controller |
nginx_ingress_controller_orphan_ingress |
Basic metric |
Status of an orphaned ingress (1 indicates an orphaned ingress).
nginx_ingress_controller_admission_config_size |
Basic metric |
Size of the tested configuration |
nginx_ingress_controller_admission_render_duration |
Basic metric |
Time required for the admission controller to render an ingress |
nginx_ingress_controller_admission_render_ingresses |
Basic metric |
Length of an ingress rendered by the admission controller |
nginx_ingress_controller_admission_roundtrip_duration |
Basic metric |
Complete duration of the admission controller at the time to process a new event (float seconds) |
nginx_ingress_controller_admission_tested_duration |
Basic metric |
Time required for admission controller tests (float seconds) |
nginx_ingress_controller_admission_tested_ingresses |
Basic metric |
Length of an ingress handled by the admission controller |
When NGINX Ingress Controller is heavily loaded, memory leakage occurs when full metric collection is enabled. For details, see the community issue. It has been verified that the memory usage increase can be effectively suppressed after the following metrics are shielded. To prevent service loss caused by memory leakage, NGINX Ingress Controller shields the following metrics by default. We will continue to pay attention to the latest news in the community and fix this issue in a timely manner.
- nginx_ingress_controller_header_duration_seconds
- nginx_ingress_controller_ingress_upstream_latency_seconds
