Priority-based Scheduling and Preemption
A pod priority indicates the importance of a pod relative to other pods. Volcano supports pod PriorityClasses in Kubernetes. After PriorityClasses are configured, the scheduler preferentially schedules high-priority pods. When cluster resources are insufficient, the scheduler will proactively evict low-priority pods to make it possible to schedule pending high-priority pods.
- A cluster of v1.19 or later is available. For details, see Buying a Standard/Turbo Cluster.
- The Volcano add-on has been installed. For details, see Volcano Scheduler.
Overview
The services running in a cluster are diversified, including core services, non-core services, online services, and offline services. You can configure priorities for different services based on service importance and SLA requirements. For example, configure a high priority for core services and online services so that such services preferentially obtain cluster resources. When cluster resources are used by non-core services and the remaining resources are insufficient for new core services, the scheduler evicts certain pods of non-core services to release the resources for scheduling the pods of the core services.
Table 1 lists the priority-based scheduling supported by CCE clusters.
| Scheduling Type | Description |
| Priority-based scheduling | The scheduler preferentially guarantees the running of high-priority pods, but will not evict low-priority pods that are running. Priority-based scheduling is enabled by default and cannot be disabled. |
| Priority-based preemption | When cluster resources are insufficient, the scheduler will proactively evict low-priority pods to make it possible to schedule pending high-priority pods. |
Configuring Priority-based Scheduling and Preemption Policies
After Volcano is installed, you can enable or disable priority-based scheduling on the Scheduling page.
- Choose Settings in the navigation pane and click the Scheduling tab.
- In the Service Priority-based Scheduling area, configure priority-based scheduling.
- Priority-based Scheduling: The scheduler preferentially guarantees the running of high-priority pods, but will not evict low-priority pods that are running. Priority-based scheduling is enabled by default and cannot be disabled.
- Priority-based Preemption: If Volcano Scheduler is used as the default scheduler of the cluster, priority-based preemption is supported. When cluster resources are insufficient, the scheduler will proactively evict low-priority pods to make it possible to schedule pending high-priority pods.
- After priority-based preemption is enabled, delayed pod creation is not allowed.
- Priority-based preemption is not allowed on custom network interface/supplementary network interface resources or host ports.
Figure 1 Priority-based scheduling
- Click Confirm.
- After the configuration, you can use PriorityClasses to schedule the pods of workloads or Volcano jobs based on priorities.
- Create one or more PriorityClasses.
apiVersion: scheduling.k8s.io/v1 kind: PriorityClass metadata: name: high-priority value: 1000000 globalDefault: false description: ""
- Create a workload or Volcano job and specify its PriorityClass name.
- Workload
apiVersion: apps/v1 kind: Deployment metadata: name: high-test labels: app: high-test spec: replicas: 5 selector: matchLabels: app: test template: metadata: labels: app: test spec: priorityClassName: high-priority schedulerName: volcano containers: - name: test image: busybox imagePullPolicy: IfNotPresent command: ['sh', '-c', 'echo "Hello, Kubernetes!" && sleep 3600'] resources: requests: cpu: 500m limits: cpu: 500m - Volcano job
apiVersion: batch.volcano.sh/v1alpha1 kind: Job metadata: name: vcjob spec: schedulerName: volcano minAvailable: 4 priorityClassName: high-priority tasks: - replicas: 4 name: "test" template: spec: containers: - image: alpine command: ["/bin/sh", "-c", "sleep 1000"] imagePullPolicy: IfNotPresent name: running resources: requests: cpu: "1" restartPolicy: OnFailure
- Workload
Example of Priority-based Scheduling
For example, if there are two idle nodes and high-, medium-, and low-priority Volcano jobs in the cluster, run the high-priority job first to exhaust the cluster resources. Then, run the medium- and low-priority jobs. The medium- and low-priority jobs are pending because the high-priority Volcano job is using all cluster resources. After the high-priority job completes, the medium-priority job is scheduled next.
- Add three PriorityClasses (high-priority, med-priority, and low-priority) in priority.yaml. Example configuration of priority.yaml:
apiVersion: scheduling.k8s.io/v1 kind: PriorityClass metadata: name: high-priority value: 100 globalDefault: false description: "This priority class should be used for volcano job only." --- apiVersion: scheduling.k8s.io/v1 kind: PriorityClass metadata: name: med-priority value: 50 globalDefault: false description: "This priority class should be used for volcano job only." --- apiVersion: scheduling.k8s.io/v1 kind: PriorityClass metadata: name: low-priority value: 10 globalDefault: false description: "This priority class should be used for volcano job only."
Create PriorityClasses.kubectl apply -f priority.yaml
- Check PriorityClasses.
kubectl get PriorityClass
Command output:NAME VALUE GLOBAL-DEFAULT AGE high-priority 100 false 97s low-priority 10 false 97s med-priority 50 false 97s system-cluster-critical 2000000000 false 6d6h system-node-critical 2000001000 false 6d6h
- Create a high-priority Volcano job to exhaust all cluster resources.
high-priority-job.yaml
apiVersion: batch.volcano.sh/v1alpha1 kind: Job metadata: name: priority-high spec: schedulerName: volcano minAvailable: 4 priorityClassName: high-priority tasks: - replicas: 4 name: "test" template: spec: containers: - image: alpine command: ["/bin/sh", "-c", "sleep 1000"] imagePullPolicy: IfNotPresent name: running resources: requests: cpu: "1" restartPolicy: OnFailureRun the following command to issue the job:
kubectl apply -f high-priority-job.yaml
Run the kubectl get pod command to check pod statuses:
NAME READY STATUS RESTARTS AGE priority-high-test-0 1/1 Running 0 3s priority-high-test-1 1/1 Running 0 3s priority-high-test-2 1/1 Running 0 3s priority-high-test-3 1/1 Running 0 3s
The command output shows that all cluster resources have been used up.
- Create a medium-priority and a low-priority Volcano job.
med-priority-job.yaml
apiVersion: batch.volcano.sh/v1alpha1 kind: Job metadata: name: priority-medium spec: schedulerName: volcano minAvailable: 4 priorityClassName: med-priority tasks: - replicas: 4 name: "test" template: spec: containers: - image: alpine command: ["/bin/sh", "-c", "sleep 1000"] imagePullPolicy: IfNotPresent name: running resources: requests: cpu: "1" restartPolicy: OnFailurelow-priority-job.yaml
apiVersion: batch.volcano.sh/v1alpha1 kind: Job metadata: name: priority-low spec: schedulerName: volcano minAvailable: 4 priorityClassName: low-priority tasks: - replicas: 4 name: "test" template: spec: containers: - image: alpine command: ["/bin/sh", "-c", "sleep 1000"] imagePullPolicy: IfNotPresent name: running resources: requests: cpu: "1" restartPolicy: OnFailureRun the following commands to issue the jobs:
kubectl apply -f med-priority-job.yaml kubectl apply -f low-priority-job.yaml
Run the kubectl get pod command to check the statuses of the pods for the newly created workloads. The command output shows that the pods are pending due to insufficient resources:
NAME READY STATUS RESTARTS AGE priority-high-test-0 1/1 Running 0 3m29s priority-high-test-1 1/1 Running 0 3m29s priority-high-test-2 1/1 Running 0 3m29s priority-high-test-3 1/1 Running 0 3m29s priority-low-test-0 0/1 Pending 0 2m26s priority-low-test-1 0/1 Pending 0 2m26s priority-low-test-2 0/1 Pending 0 2m26s priority-low-test-3 0/1 Pending 0 2m26s priority-medium-test-0 0/1 Pending 0 2m36s priority-medium-test-1 0/1 Pending 0 2m36s priority-medium-test-2 0/1 Pending 0 2m36s priority-medium-test-3 0/1 Pending 0 2m36s
- Delete the high-priority job to release cluster resources. The medium-priority job will be scheduled next.
Run the kubectl delete -f high-priority-job.yaml command to release cluster resources and check pod scheduling.
NAME READY STATUS RESTARTS AGE priority-low-test-0 0/1 Pending 0 5m18s priority-low-test-1 0/1 Pending 0 5m18s priority-low-test-2 0/1 Pending 0 5m18s priority-low-test-3 0/1 Pending 0 5m18s priority-medium-test-0 1/1 Running 0 5m28s priority-medium-test-1 1/1 Running 0 5m28s priority-medium-test-2 1/1 Running 0 5m28s priority-medium-test-3 1/1 Running 0 5m28s
Example of Priority-based Preemption
- In the navigation pane, choose Settings and click the Scheduling tab.
- Modify configurations.
- Select Volcano scheduler as the default cluster scheduler.
- Enable Priority-based Preemption.
- Issue another high-priority Volcano job. The scheduler will evict the medium-priority job to ensure successful scheduling of the high-priority job.
Run the kubectl apply -f high-priority-job.yaml command to issue the high-priority job. Then, check pod statuses.
NAME READY STATUS RESTARTS AGE priority-high-test-0 0/1 Pending 0 2s priority-high-test-1 0/1 Pending 0 2s priority-high-test-2 0/1 Pending 0 2s priority-high-test-3 0/1 Pending 0 2s priority-low-test-0 0/1 Pending 0 14s priority-low-test-1 0/1 Pending 0 14s priority-low-test-2 0/1 Pending 0 14s priority-low-test-3 0/1 Pending 0 14s priority-medium-test-0 1/1 Terminating 0 21s priority-medium-test-1 1/1 Terminating 0 21s priority-medium-test-2 1/1 Terminating 0 21s priority-medium-test-3 1/1 Terminating 0 21s
After the resources used by the medium-priority job are released, the high-priority job can be scheduled.
NAME READY STATUS RESTARTS AGE priority-high-test-0 1/1 Running 0 70s priority-high-test-1 1/1 Running 0 70s priority-high-test-2 1/1 Running 0 70s priority-high-test-3 1/1 Running 0 70s priority-low-test-0 0/1 Pending 0 82s priority-low-test-1 0/1 Pending 0 82s priority-low-test-2 0/1 Pending 0 82s priority-low-test-3 0/1 Pending 0 82s priority-medium-test-0 0/1 Pending 0 37s priority-medium-test-1 0/1 Pending 0 36s priority-medium-test-2 0/1 Pending 0 37s priority-medium-test-3 0/1 Pending 0 37s
When node resources are insufficient for the high-priority job, priority-based preemption by volcano-scheduler will be triggered. The medium-priority job will be evicted to deploy the high-priority job. After new nodes are added using Cluster Autoscaler, volcano-scheduler will schedule the medium-priority job to the new nodes.
According to the preceding test results, enable node scaling if priority-based preemption is enabled so that cluster resources can be allocated on demand to ensure service SLA.
Example of Affinity and Anti-affinity for Priority-based Preemption
Do not configure inter-pod affinity on the pods with lower priorities. If a pod in the pending state is inter-pod affinity with one or more pods with lower priorities on the node, the pod affinity rule cannot be met when preemption is initiated for the pods with lower priorities, and the preemption rule conflicts with the affinity rule. In this case, the scheduler cannot ensure the scheduling of the pending pod. To resolve this issue, configure inter-pod affinity only for pods with the same or higher priority. For details, see Inter-pod affinity on lower-priority pods.
In inter-pod affinity, if priority-based preemption is enabled and deploy1 is affinity with lower-priority deploy2, volcano-scheduler will evict deploy3 and schedule deploy1 to the node to ensure service O&M. The evicted deploy3 will be scheduled to the new node after the new node is ready.
In inter-pod anti-affinity, if priority-based preemption is enabled and deploy1 is anti-affinity with deploy2 and deploy3, volcano-scheduler will not evict deploy2 and deploy3 to minimize the impact on other services. Instead, the scheduler will schedule deploy1 to a new node.
