Updated on 2025-11-06 GMT+08:00
Node Pool Affinity
In scenarios such as node pool replacement and rolling node upgrade, an old resource pool needs to be replaced with a new one. To prevent the node pool replacement from affecting services, enable soft affinity to schedule service pods to the new node pool. Soft affinity scheduling tries to schedule newly created pods or rescheduled pods to the new node pool. If the pods cannot be scheduled to the new node pool, for example, due to insufficient resources, the pods can also be scheduled to the old node pool. Since a node pool replacement should not affect services, the node affinity configuration is not declared in service workloads. Use soft affinity in cluster scheduling to schedule pods to new node pools when a pool replacement is triggered.
Volcano aims to soft schedule service pods to specified nodes when node soft affinity is not configured on service workloads.
Scheduling Priority
Soft affinity scheduling of a node pool is implemented based on labels in the node pool. Each node in the node pool is scored to select the optimal one for pod scheduling.
The rule is to schedule pods to nodes with specified labels as far as possible.
The scoring formula is as follows:
Node score = Weight x MaxNodeScore x haveLabel
Parameters:
  • Weight: weight of the soft affinity add-on in the node pool.
  • MaxNodeScore: maximum score (100) of a node.
  • haveLabel: whether the labels configured in the add-on are available on a node. If yes, the value is 1. If no, the value is 0.
Configuring Soft Affinity Scheduling for Volcano Node Pools
  1. Configure labels for affinity scheduling in the node pool.
    2. Choose Nodes in the navigation pane and click the Node Pools tab on the right.
    3. Click Update of the target node pool. On the page that is displayed, configure labels in the Kubernetes Label area.
      The following is an example.
  2. In the navigation pane, choose Settings and click the Scheduling tab. Select Volcano, find the expert mode, and click Refresh.
  3. Configure Volcano scheduler parameters. The following shows a configuration example in JSON format:
        "default_scheduler_conf": {
            "actions": "allocate, backfill, preempt",
            "tiers": [
                    "plugins": [
                            "name": "priority"
                            "name": "gang"
                            "name": "conformance"
                    "plugins": [
                            "name": "drf"
                            "name": "predicates"
                            "name": "nodeorder"
                    "plugins": [
                            "name": "cce-gpu-topology-predicate"
                            "name": "cce-gpu-topology-priority"
                            "name": "cce-gpu"
                            // Enable node pool affinity scheduling.
                            "name": "nodepoolaffinity",
                            // Configure the affinity scheduling weight and labels of the node pool.
                            "arguments": {
                                "nodepoolaffinity.weight": 10000,
                                "nodepoolaffinity.label": "nodepool=nodepool1"
                    "plugins": [
                            "name": "nodelocalvolume"
                            "name": "nodeemptydirvolume"
                            "name": "nodeCSIscheduling"
                            "name": "networkresource"
  4. Click OK.
