Help Center/ Cloud Container Engine/ User Guide/ Node Pools/ Managing Node Pools/ Copying a Node Pool
Updated on 2026-06-16 GMT+08:00
Copying a Node Pool
You can copy the configuration of an existing node pool on the CCE console to create new node pools.
- There is no node in a newly created node pool. You can manually add nodes to it or enable auto scaling to have nodes added automatically.
- When a node pool is copied, only resource settings (such as node flavor, OS, storage, and network) and advanced settings (such as labels and taints) related to node pool creation are copied. Post-creation settings, such as auto scaling and component management, are not copied.
- Log in to the CCE console.
- Click the cluster name to access the cluster console. Choose Nodes in the navigation pane. In the right pane, click the Node Pools tab.
- Choose More > Copy in the Operation column of the target node pool. Figure 1 Copying a node pool
- On the Copy Node Pool page, view the settings of the copied node pool and modify them as needed. Login Mode and Associate Security Group need to be confirmed separately. Other configuration items inherit the settings of the original node pool. For details, see Creating a Node Pool. After confirming the configuration, click Next: Confirm.
- On the Confirm page, confirm the node pool settings, read the usage instructions, select the check box, and click Submit. Then, a new node pool is created based on the modified settings.
