Help Center/ Cloud Container Engine/ User Guide/ Clusters/ Upgrade Management/ Troubleshooting for Pre-upgrade Check Exceptions/ Health of Master Node Components
Updated on 2025-11-06 GMT+08:00
Check Items
Check whether cluster components such as Kubernetes components, container runtime component, and network component are running properly before the upgrade.
Perform the pre-upgrade check again.
If it fails again, submit a service ticket to contact technical support.
