Updated on 2026-09-21 GMT+08:00
Storage Basics
Volumes
On-disk files in a container are ephemeral, which presents the following problems to important applications running in the container:
  • When a container is rebuilt, files in the container will be lost.
  • When multiple containers run in a pod at the same time, files need to be shared among the containers.
Kubernetes volumes resolve both of these problems. Volumes, as part of a pod, cannot be created independently and can only be defined in pods. All containers in a pod can access its volumes, but the volumes must have been mounted to any directory in a container.
The following figure shows how a storage volume is used between containers in a pod.
The basic principles for using volumes are as follows:
  • Multiple volumes can be mounted to a pod. However, do not mount too many volumes to a pod.
  • Multiple types of volumes can be mounted to a pod.
  • Each volume mounted to a pod can be shared among containers in the pod.
  • You are advised to use PVCs and PVs to mount volumes for Kubernetes.
The lifecycle of a volume is the same as that of the pod to which the volume is mounted. When the pod is deleted, the volume is also deleted. However, files in the volume may outlive the volume, depending on the volume type.
Kubernetes provides various volume types, which can be classified as in-tree and out-of-tree.
Volume Classification
In-tree
Maintained through the Kubernetes code repository and built, edited, and released with Kubernetes binary files. Kubernetes does not accept new in-tree volume types anymore.
For example, hostPath, emptyDir, secrets, and ConfigMaps are in-tree volumes supported by Kubernetes.
PVCs are a special in-tree volume. Kubernetes uses this type of volume for conversion from in-tree to out-of-tree. PVCs allow you to request PVs created using the underlying storage resources provided by different storage vendors.
Out-of-tree
Out-of-tree volumes include container storage interfaces (CSIs) and FlexVolumes (deprecated). Storage vendors only need to comply with certain specifications to create custom storage add-ons and PVs that can be used by Kubernetes, without adding add-on source code to the Kubernetes code repository. Cloud storage services such as SFS and OBS are accessed by installing storage drivers in a cluster. You need to create PVs in the cluster and mount them to pods using PVCs.
PV and PVC
Kubernetes provides PersistentVolumes (PVs) and PersistentVolumeClaims (PVCs) to abstract details of how storage is provided from how it is consumed. You can request specific size of storage when needed, just like pods can request specific levels of resources (CPU and memory).
  • PV: describes a persistent storage volume in a cluster. A PV is a cluster-level resource just like a node. It applies to the entire Kubernetes cluster. A PV has a lifecycle independent of any individual Pod that uses the PV.
  • PVC: describes a request for storage by a user. When configuring storage for an application, claim a storage request (that is, PVC). Kubernetes selects a PV that best meets the request and binds the PV to the PVC. A PVC to PV binding is a one-to-one mapping. When creating a PVC, describe the attributes of the requested persistent storage, such as the storage size and read/write permission.
You can bind PVCs to PVs in a pod so that the pod can use storage resources. The following figure shows the relationship between PVs and PVCs.
Figure 1 PVC-to-PV binding
CSI
CSI is a standard for container storage interfaces and a storage plugin implementation solution recommended by the Kubernetes community. CCE Container Storage (Everest) is a storage add-on developed based on CSI. It provides different types of persistent storage for containers.
Volume Access Modes
Storage volumes can be mounted to the host system only in the mode supported by underlying storage resources. For example, a file storage system can be read and written by multiple nodes, but an EVS disk can be read and written by only one node.
  • ReadWriteOnce: A storage volume can be mounted to a single node in read-write mode.
  • ReadWriteMany: A storage volume can be mounted to multiple nodes in read-write mode.
Table 1 Access modes supported by storage volumes
Volume Type
ReadWriteOnce
ReadWriteMany
EVS
Yes
No
SFS
No
Yes
OBS
No
Yes
SFS Turbo
No
Yes
Local PV
Yes
No
DSS
Yes
No
Mounting a Storage Volume
You can mount volumes in the following ways:
Table 2 Modes of mounting volumes
Mount Mode
Supported Volume Type
Other Constraints
Statically creating a storage volume (using existing storage)
You can manually create PVs and PVCs using existing storage resources, such as EVS disks or SFS file systems. Kubernetes automatically matches and binds the PVC to a suitable PV based on the resource requirements specified in the PVC. Once bound, the PVC can be mounted to a workload, enabling the workload to access the storage resources for persistent data storage.
If the PV's access mode is ReadWriteOnce, the workload can only run on a single pod.
All volumes
None
Dynamically creating a storage volume (automatically creating storage)
You can specify a StorageClass in a PVC. The storage provisioner will then dynamically create the underlying storage resources and a PV based on the resource requirements declared in the PVC. The PV is automatically bound to the PVC, enabling automatic provisioning of storage resources.
EVS, DSS, OBS, SFS, and local PV
None
Dynamic mounting (VolumeClaimTemplate)
Dynamic mounting is achieved using volumeClaimTemplates and relies on the dynamic PV creation capability of the specified StorageClass. In this mode, each pod is associated with a unique PVC and PV. After a pod is rescheduled, it can still mount the original data based on the PVC name.
Even if the PV's access mode is ReadWriteOnce, the workload can still run on multiple pods.
EVS, DSS, and local PV
Supported only by StatefulSets
PV Reclaim Policy
A PV reclaim policy is used to delete or reclaim underlying volumes when a PVC is deleted. The value can be Delete or Retain.
  • Delete: Deleting a PVC will remove the PV from Kubernetes, and the associated underlying storage assets will also be removed from the external infrastructure.
    Yearly/Monthly EVS disks can be deleted along with the node to which they are attached. However, other types of yearly/monthly resources cannot be deleted in this manner.
  • Retain: When a PVC is deleted, both the PV and underlying storage resources will be retained. You need to manually delete these resources. After the PVC is deleted, the PV is in the Released state and cannot be bound to a PVC again.
    You can manually delete and reclaim volumes by performing the following operations:
    1. Delete the PV.
    2. Clear data on the associated underlying storage resources as required.
    3. Delete the associated underlying storage resources.
    If you want to continue using the underlying storage resources, delete the PV first. Then, create a new PV and PVC and associate them with the underlying storage resources.
CCE also allows you to delete a PVC without deleting underlying storage resources. This function can be achieved only by using a YAML file: Set the PV reclaim policy to Delete and add everest.io/reclaim-policy: retain-volume-only to annotations. In this way, when the PVC is deleted, the PV is deleted, but the underlying storage resources are retained.
The following YAML file takes EVS as an example:
apiVersion: v1
kind: PersistentVolumeClaim
  namespace: default
  annotations:
    volume.beta.kubernetes.io/storage-provisioner: everest-csi-provisioner
    everest.io/disk-volume-type: SAS
  labels:
    failure-domain.beta.kubernetes.io/region: <your_region>   # Region of the node where the application is to be deployed
    failure-domain.beta.kubernetes.io/zone: <your_zone>       # AZ of the node where the application is to be deployed
  accessModes:
    - ReadWriteOnce
  resources:
    requests:
      storage: 10Gi
  storageClassName: csi-disk
  volumeName: pv-evs-test
apiVersion: v1
  annotations:
    pv.kubernetes.io/provisioned-by: everest-csi-provisioner
  labels:
  accessModes:
    - ReadWriteOnce
  capacity:
    storage: 10Gi
  csi:
    driver: disk.csi.everest.io
    fsType: ext4
    volumeHandle: 2af98016-6082-4ad6-bedc-1a9c673aef20 # EVS disk ID
    volumeAttributes:
      storage.kubernetes.io/csiProvisionerIdentity: everest-csi-provisioner
      everest.io/disk-mode: SCSI
  persistentVolumeReclaimPolicy: Delete
StorageClasses
StorageClasses are resource objects that define storage types in Kubernetes. They enable dynamic provisioning of storage volumes. Once you modify the parameter settings of a StorageClass, it can automatically provision and adjust storage resources based on service requirements. When you specify a StorageClass name (StorageClassName) in a PVC, Kubernetes will automatically provision a PV and the underlying storage resources based on the requirements declared in the PVC. If no matching PV is found in the cluster, Kubernetes will call the target provisioner specified in the StorageClass to create a new PV and storage resources. This simplifies the process of manually creating and maintaining PVs. The StorageClass defines default parameters for storage provisioning. If there are conflicts between the StorageClass settings and the PVC settings, the PVC settings will take precedence.
The following table lists default StorageClasses offered by CCE. These default StorageClasses cannot be modified. If the default StorageClasses cannot meet your service requirements, you can create a new StorageClass and set parameters such as the reclaim policy and binding mode. For details, see Customizing a StorageClass.
Compared with csi-local and csi-disk, csi-local-topology and csi-disk-topology support delayed creation of storage volumes. That means a storage volume is created after the pod associated with the storage volume is scheduled onto a specified node. This prevents conflicts between storage volume provisioning and other pod scheduling constraints. For details, see Topology-Aware Volume Provisioning in Kubernetes. For this reason, you are advised to use a StorageClass that supports this setting.
Table 3 Default StorageClasses
StorageClass Name
Storage Type
Provisioner
Reclaim Policy
Binding
Capacity Expansion
csi-disk
EVS
Delete
Immediate
Supported
csi-disk-topology
EVS disk created with a delay
Delete
WaitForFirstConsumer
Supported
csi-nas
SFS Capacity-Oriented
Delete
Immediate
Supported
csi-sfs
General Purpose File System (SFS 3.0 Capacity-Oriented)
Delete
Immediate
Not supported
csi-sfsturbo
SFS Turbo
Delete
Immediate
Supported
csi-obs
OBS
Delete
Immediate
Not supported
csi-disk-dss
DSS
Delete
Immediate
Supported
csi-local
Local PV
Delete
Immediate
Not supported
csi-local-topology
Local PV created with a delay
Delete
Supported
The parameters in Table 3 are described as follows:
  • Storage Type: The underlying storage type created by the StorageClass.
  • Provisioner: The storage resource provisioner.
  • Reclaim Policy: The policy for reclaiming the underlying storage when the PVC is deleted. For details, see PV Reclaim Policy.
  • Binding Mode: How a volume is bound when a PV is dynamically created. The value can be Immediate or WaitForFirstConsumer.
    • Immediate: When a PVC is created, the storage resources and PV are created and bound to the PVC immediately, without delay.
    • WaitForFirstConsumer: When a PVC is created, it is not immediately bound to a PV. Instead, the storage resources and PV are created and bound to the PVC only after the pod that requires the PVC is scheduled.
  • Capacity Expansion: Whether the PV created using the StorageClass supports dynamic capacity expansion.
For more information about the default StorageClasses, see Accessing a Cluster Using kubectl. Run kubectl describe sc <storageclass-name> for detailed information.
Helpful Links
  • For more information about Kubernetes storage, see Storage.
  • For more information about CCE container storage, see Storage Overview.
