Configuring SFS Volume Mount Options
This section describes how to configure SFS mount options. You can configure mount options in a PV and bind the PV to a PVC. Alternatively, configure mount options in a StorageClass and use the StorageClass to create a PVC. In this way, PVs can be dynamically created and inherit mount options configured in the StorageClass by default.
The CCE Container Storage (Everest) version must be 1.2.8 or later. This add-on identifies the mount options and transfers them to the underlying storage resources. The parameter settings take effect only if the underlying storage resources support the specified options.
- Mount options cannot be configured for secure containers.
- Due to the restrictions of the NFS protocol, if an SFS volume is mounted to a node for multiple times, link-related mounting parameters (such as timeo) take effect only when the SFS volume is mounted for the first time by default. For example, if the same SFS file system is mounted to multiple pods running on a node, the mounting parameter set later does not overwrite the existing parameter value. If you want to configure different mounting parameters in the preceding scenario, additionally configure the nosharecache parameter.
The Everest add-on in CCE presets the options described in Table 1 for mounting SFS volumes.
Parameter |
Value |
Description |
keep-original-ownership |
Blank |
Whether to retain the ownership of the file mount point. If this option is used, the Everest add-on must be v1.2.63 or v2.1.2 or later.
vers |
3 |
File system version. Currently, only NFSv3 is supported. Value: 3 |
nolock |
Blank |
Whether to lock files on the server using the NLM protocol. If nolock is selected, the lock is valid for applications on one host. For applications on another host, the lock is invalid. |
timeo |
600 |
Waiting time before the NFS client retransmits a request. The unit is 0.1 seconds. Recommended value: 600 |
hard/soft |
Blank |
Mount mode.
The default value is hard. |
sharecache/nosharecache |
Blank |
How the data cache and attribute cache are shared when one file system is concurrently mounted to different clients. If this parameter is set to sharecache, the caches are shared between the mountings. If this parameter is set to nosharecache, the caches are not shared, and one cache is configured for each client mounting. The default value is sharecache.
The nosharecache setting will affect the performance. The mounting information must be obtained for each mounting, which increases the communication overhead with the NFS server and the memory consumption of the NFS clients. In addition, the nosharecache setting on the NFS clients may lead to inconsistent caches. Determine whether to use nosharecache based on site requirements. |
You can configure other mount options if needed. For details, see Mounting an NFS File System to ECSs (Linux).
Configuring Mount Options
You can configure mount options using one of the following methods.
You can use the mountOptions field to configure mount options in a PV. The options you can configure in mountOptions are listed in SFS Volume Mount Options.
- Use kubectl to access the cluster. For details, see Accessing a Cluster Using kubectl.
- Configure mount options in a PV. Example:
apiVersion: v1 kind: PersistentVolume metadata: annotations: pv.kubernetes.io/provisioned-by: everest-csi-provisioner everest.io/reclaim-policy: retain-volume-only # (Optional) The underlying volume is retained when the PV is deleted. name: pv-sfs spec: accessModes: - ReadWriteMany # Access mode. The value must be ReadWriteMany for SFS. capacity: storage: 1Gi # Storage capacity. This parameter is only for verification. It must not be empty or 0, but the specified size will not take effect. csi: driver: nas.csi.everest.io # Dependent storage driver for the mounting fsType: nfs volumeHandle: <your_volume_id> # The ID of the SFS Capacity-Oriented volume volumeAttributes: everest.io/share-export-location: <your_location> # Shared path of the SFS volume storage.kubernetes.io/csiProvisionerIdentity: everest-csi-provisioner persistentVolumeReclaimPolicy: Retain # Reclaim policy storageClassName: csi-nas # StorageClass name. mountOptions: # Mount options - vers=3 - nolock - timeo=600 - hard - After creating a PV, you can create a PVC, bind it to the PV, and mount the PV to the containers in the workload. For details, see Using an Existing SFS File System Through a Static PV.
- Check whether the mount options are effective.
In this example, the PVC is mounted to the workload that uses the nginx:latest image. You can run the mount -l command to check whether the mount options take effect.
- View the pod to which the SFS volume has been mounted. In this example, the workload name is web-sfs.
kubectl get pod | grep web-sfs
Command output:
web-sfs-*** 1/1 Running 0 23m
- Run the following command to check the mount options (web-sfs-*** is an example pod):
kubectl exec -it web-sfs-*** -- mount -l | grep nfsIf the mounting information in the command output is consistent with the configured mount options, the mount options have been configured.
<Your shared path> on /data type nfs (rw,relatime,vers=3,rsize=1048576,wsize=1048576,namlen=255,hard,nolock,noresvport,proto=tcp,timeo=600,retrans=2,sec=sys,mountaddr=**.**.**.**,mountvers=3,mountport=2050,mountproto=tcp,local_lock=all,addr=**.**.**.**)
You can use mountOptions to configure mount options in a StorageClass. The options you can configure in mountOptions are listed in SFS Volume Mount Options.
- Create a custom StorageClass. Example:
apiVersion: storage.k8s.io/v1 kind: StorageClass metadata: name: csi-sfs-mount-option provisioner: everest-csi-provisioner parameters: csi.storage.k8s.io/csi-driver-name: nas.csi.everest.io csi.storage.k8s.io/fstype: nfs everest.io/share-access-to: <your_vpc_id> # VPC ID of the cluster reclaimPolicy: Delete volumeBindingMode: Immediate mountOptions: # Mount options - vers=3 - nolock - timeo=600 - hard
- After the StorageClass is configured, you can use it to create a PVC. By default, dynamically created PVs inherit the mount options configured in the StorageClass. For details, see Using an SFS File System Through a Dynamic PV.
Command output:
