Updated on 2026-09-21 GMT+08:00
(kubectl) Creating a PV from an Existing SFS File System
Notes and Constraints
The following configuration example applies to clusters of Kubernetes 1.13 or earlier.
  1. Log in to the SFS console, create a file system, and record the file system ID, shared path, and capacity.
  2. Use kubectl to connect to the cluster. For details, see Accessing a Cluster Using kubectl.
  3. Create two YAML files for creating the PV and PVC. Assume that the file names are pv-sfs-example.yaml and pvc-sfs-example.yaml.
    touch pv-sfs-example.yaml pvc-sfs-example.yaml
    Kubernetes Cluster Version
    YAML Example
    1.11 ≤ K8s version < 1.13
    Clusters from v1.11 to v1.13
    Example YAML
    K8s version = 1.9
    Clusters of v1.9
    Example YAML
    • Example YAML file for the PV:
      apiVersion: v1
      kind: PersistentVolume
        annotations:
          pv.kubernetes.io/provisioned-by: flexvolume-huawei.com/fuxinfs
        accessModes:
        - ReadWriteMany
        capacity:
          storage: 10Gi
        claimRef:
          apiVersion: v1
          kind: PersistentVolumeClaim
          namespace: default
        flexVolume:
          driver: huawei.com/fuxinfs
          fsType: nfs
          options:
            deviceMountPath: <your_deviceMountPath>  # Shared storage path of your file.
            fsType: nfs
            volumeID: f6976f9e-2493-419b-97ca-d7816008d91c
        persistentVolumeReclaimPolicy: Delete
        storageClassName: nfs-rw
      Table 1 Key parameters
      driver
      Storage driver used to mount the volume. Set the driver to huawei.com/fuxinfs for the file system.
      deviceMountPath
      Shared path of the file system.
      On the management console, choose Service List > Storage > Scalable File Service. You can obtain the shared path of the file system from the Mount Address column, as shown in Figure 1.
      volumeID
      File system ID.
      To obtain the ID, log in to the CCE console, choose Resource Management > Storage, click the PVC name in the SFS tab page, and copy the PVC ID on the PVC details page.
      storage
      File system size.
      storageClassName
      Read/write mode supported by the file system. Currently, nfs-rw and nfs-ro are supported.
      spec.claimRef.apiVersion
      The value is fixed at v1.
      spec.claimRef.kind
      The value is fixed at PersistentVolumeClaim.
      spec.claimRef.name
      The value is the same as the name of the PVC created in the next step.
      spec.claimRef.namespace
      Namespace of the PVC. The value is the same as the namespace of the PVC created in the next step.
    • Example YAML file for the PVC:
      apiVersion: v1
        annotations:
          volume.beta.kubernetes.io/storage-class: nfs-rw
          volume.beta.kubernetes.io/storage-provisioner: flexvolume-huawei.com/fuxinfs
        namespace: default
        accessModes:
        - ReadWriteMany
        resources:
          requests:
            storage: 10Gi
        volumeName: pv-sfs-example
      Table 2 Key parameters
      Read/write mode supported by the file system. nfs-rw and nfs-ro are supported. The value must be the same as that of the existing PV.
      Must be set to flexvolume-huawei.com/fuxinfs.
      storage
      Storage capacity, in the unit of Gi. The value must be the same as the storage size of the existing PV.
      volumeName
      Name of the PV.
    Clusters of v1.9
      apiVersion: v1
        namespace: default
        accessModes:
        - ReadWriteMany
        capacity:
          storage: 10Gi
        flexVolume:
          fsType: nfs
          options:
            fsType: nfs
            kubernetes.io/namespace: default
      Table 3 Key parameters
      driver
      deviceMountPath
      volumeID
      File system ID.
      storage
      File system size.
      storageClassName
      apiVersion: v1
        annotations:
        namespace: default
        accessModes:
        - ReadWriteMany
        resources:
          requests:
            storage: 10Gi
        volumeNamespace: default
      Table 4 Key parameters
      The field must be set to flexvolume-huawei.com/fuxinfs.
      storage
      volumeName
      Name of the PV.
    Figure 1 SFS - file system mount address
    The VPC to which the file system belongs must be the same as the VPC of the ECS VM to which the workload is planned.
  4. Create a PV.
    kubectl create -f pv-sfs-example.yaml
  5. Create a PVC.
    kubectl create -f pvc-sfs-example.yaml
