Binding a Security Group to a Workload Using a Security Group Policy
In Cloud Native Network 2.0, pods use VPC network interfaces or supplementary network interfaces for networking. You can directly bind security groups and EIPs to pods. To bind CCE pods with security groups, CCE provides a custom resource object named SecurityGroup. Using this resource object, you can customize security isolation for workloads.
Security groups can be associated with workloads through multiple methods: annotations, security group policies, node pool settings, or pod network settings. When multiple methods are used, only the highest-priority method applies. For details about priorities, see Comparison of Workload Security Group Configuration Methods.
Notes and Constraints
This function is available in CCE Turbo clusters v1.19 and later. Upgrade your CCE Turbo clusters if their versions are earlier than v1.19.
Creating a Security Group Policy
Use one of the following methods.
- In the navigation pane, choose Workloads. On the displayed page, click the desired workload name.
- Switch to the SecurityGroups tab and click Create.
- Set the parameters as described in Table 1.
Table 1 Configuration parameters Parameter
Example
Policy Name
Enter a security policy name.
Enter 1 to 63 characters. The value must start with a lowercase letter and cannot end with a hyphen (-). Only lowercase letters, digits, and hyphens (-) are allowed.
security-group
Associate Security Group
The selected security group will be bound to the network interface or supplementary network interface of the selected workload. You are required to select the security group from the drop-down list. For better network performance, select no more than five security groups.
If no security group has been created, click Create Security Group. After the security group is created, click the refresh button.
NOTE:Hover the cursor on the security group name. You can obtain details about the security group.
64566556-bd6f-48fb-b2c6-df8f44617953
5451f1b0-bd6f-48fb-b2c6-df8f44617953
- After setting the parameters, click OK.
After the security group is created, the system automatically returns to the security group list page where you can see the new security group.
- Use kubectl to access the cluster. For details, see Accessing a Cluster Using kubectl.
- Create a description file named securitygroup-demo.yaml.
vi securitygroup-demo.yaml
For example, create the following SecurityGroup to associate all nginx workloads with two security groups 64566556-bd6f-48fb-b2c6-df8f44617953 and 5451f1b0-bd6f-48fb-b2c6-df8f44617953 that have been created in advance. An example is as follows:
apiVersion: crd.yangtse.cni/v1 kind: SecurityGroup metadata: name: demo namespace: default spec: podSelector: matchLabels: app: nginx securityGroups: - id: 64566556-bd6f-48fb-b2c6-df8f44617953 - id: 5451f1b0-bd6f-48fb-b2c6-df8f44617953Table 2 describes the parameters in the YAML file.Table 2 Description Field
Mandatory
apiVersion
API version. The value is crd.yangtse.cni/v1.
Yes
kind
Type of the object to be created.
Yes
metadata
Metadata definition of the resource object.
Yes
name
Name of the SecurityGroup.
Yes
namespace
Name of the namespace.
Yes
spec
Detailed description of the SecurityGroup.
Yes
podSelector
Used to define the workload to be associated with security groups in the SecurityGroup.
Yes
securityGroups
Security group ID.
Yes
- Run the following command to create the SecurityGroup:
kubectl create -f securitygroup-demo.yaml
If the following information is displayed, the SecurityGroup is being created.
securitygroup.crd.yangtse.cni/demo created
- Run the following command to check the SecurityGroup:
kubectl get sg
If the name of the created SecurityGroup is demo in the command output, the SecurityGroup is created successfully.
NAME POD-SELECTOR AGE all-no map[matchLabels:map[app:nginx]] 4h1m s001test map[matchLabels:map[app:nginx]] 19m demo map[matchLabels:map[app:nginx]] 2m9s
