Updated on 2026-09-21 GMT+08:00
Service Overview
In Kubernetes, a Service makes an application running on a set of pods network-accessible. It provides a consistent DNS name for these pods and distributes traffic across them for load balancing. This section describes the basic concepts of Kubernetes Services and provides a comparison of various Service types.
Basic Concepts
You need to understand the following concepts about Services.
Service Types
You can create a specified type of Service in a cluster. The description and application scenarios of different types of Services are listed in the table below.
Service Type
Application
Billing
ClusterIP
ClusterIP Services are the default type of Kubernetes Services. They assign a virtual IP address, accessible only within the cluster, from the cluster's Service CIDR block.
Services that only need to communicate with each other within a cluster and do not need to be exposed outside the cluster.
For example, if a frontend application pod in a cluster needs to access a backend database in the same cluster, you can create a ClusterIP Service for the backend database to ensure that the backend database can be accessed only within the cluster.
Creating a Service of this type does not incur any costs.
NodePort
A NodePort Service opens a port on each node in a cluster to allow external traffic to access the Service through <node-IP-address>:<node-port>.
Scenarios where temporary or low-volume access is required.
For example, in a testing environment, you can use a NodePort Service when deploying and debugging a web application.
To access a NodePort Service from the Internet, bind an EIP to the node. For details about EIP billing, see EIP Billing Composition.
LoadBalancer
A LoadBalancer Service adds an external load balancer on the top of a NodePort Service and distributes external traffic to multiple pods within a cluster. It automatically assigns an external IP address to allow access from the clients. LoadBalancer Services process TCP and UDP traffic at Layer 4 (transport layer) of the OSI model. They can be extended to support Layer 7 (application layer) capabilities to manage HTTP and HTTPS traffic.
Cloud applications that require a stable, easy-to-manage entry for external access.
For example, in a production environment, you can use LoadBalancer Services to expose public-facing services such as web applications and API services to the Internet. These services often need to handle heavy traffic while maintaining high availability.
Load balancers are billed. For details, see ELB Billing.
DNAT
A DNAT Service provides Network Address Translation (NAT) for all nodes in a cluster so that multiple nodes can share an EIP.
Services that require temporary or low-volume access from the Internet. DNAT Services provide higher reliability than NodePort Services. With a DNAT Service, there is no need to bind an EIP to a single node, and requests can still be distributed to the workload even if any node fails.
NAT gateways are billed. For details, see NAT Gateway Billing.
Headless Services
For headless Services, no cluster IP address is allocated. When a client attempts to access a backend pod and performs a DNS query for the Service, it receives a list of the IP addresses of the backend pods. This allows the client to communicate directly with individual pods.
Applications that require direct communication with specific backend pods instead of using proxies or load balancers.
For example, when you deploy a stateful application (such as a ClickHouse database), you can use a headless Service. It allows application pods to directly access each ClickHouse pod and enables targeted read and write operations. This enhances overall data processing efficiency.
Why a Service Fails to Be Accessed from Within the Cluster
If the service affinity of a Service is set to the node level, that is, the value of externalTrafficPolicy is Local, the Service may fail to be accessed from within the cluster (specifically, nodes or containers). Information similar to the following is displayed:
upstream connect error or disconnect/reset before headers. reset reason: connection failure
Or
curl: (7) Failed to connect to **.**.**.** port 900: Connection refused
Or
curl: (28) Failed to connect to **.**.**.** port 1122: Connection timed out
It is common that a load balancer in a cluster cannot be accessed. The reason is as follows: When Kubernetes creates a Service, kube-proxy adds the access address of the load balancer as an external IP address (External-IP, as shown in the following command output) to iptables or IPVS. If a client inside the cluster initiates a request to access the load balancer, the address is considered as the external IP address of the Service, and the request is directly forwarded by kube-proxy without passing through the load balancer outside the cluster.
# kubectl get svc nginx
NAME    TYPE           CLUSTER-IP      EXTERNAL-IP                   PORT(S)        AGE
nginx   LoadBalancer   10.247.76.156   123.**.**.**,192.168.0.133   80:32146/TCP   37s
When the value of externalTrafficPolicy is Local, the access failures in different container network models and service forwarding modes are as follows:
  • For a multi-pod workload, ensure that all pods are accessible. Otherwise, there is a possibility that the access to the workload fails.
  • The table lists only the scenarios where the access may fail. Other scenarios that are not listed in the table indicate that the access is normal.
  • For CCE clusters using IPVS, set externalTrafficPolicy to Local for node-level Service affinity. For CCE Turbo clusters with DataPlane V2 disabled, node-level affinity is supported only when the Service backend uses hostNetwork.
  • For CCE clusters using IPTABLES, set externalTrafficPolicy to Local for node-level Service affinity. For CCE Turbo clusters with DataPlane V2 disabled, node-level affinity is supported only when the Service backend uses hostNetwork.
  • For clusters with DataPlane V2 enabled, set externalTrafficPolicy to Local for node-level Service affinity.
    DataPlane V2 is supported only in CCE VPC-network clusters and Turbo clusters. Once enabled, it replaces kube-proxy entirely, eliminating the need to configure a service forwarding mode. For details, see DataPlane V2.
The following methods can be used to solve this problem:
  • (Recommended) In the cluster, use the ClusterIP Service or service domain name for access.
  • Set externalTrafficPolicy of the Service to Cluster, which means cluster-level service affinity. Note that this affects source address persistence.
    Assume that the Service name is my-service and it is in the default namespace. The kubectl command example is as follows:
    kubectl patch service my-service -n default --type='merge' -p '{"spec":{"externalTrafficPolicy":"Cluster"}}'
  • Leveraging the pass-through feature of the Service, kube-proxy is bypassed when the ELB address is used for access. The ELB load balancer is accessed first, and then the workload. For details, see Configuring Passthrough Networking for a LoadBalancer Service.
    • In a CCE standard cluster, after passthrough networking is configured using a dedicated load balancer, the private IP address of the load balancer cannot be accessed from the node where a workload pod resides or other pods on the same node as the workload.
    • This function is only available in clusters v1.19 and later.
    • In IPVS, the passthrough settings of Services connected to the same load balancer must be the same.
    • If node-level (local) service affinity is used, kubernetes.io/elb.pass-through is automatically set to onlyLocal to enable passthrough networking.
Helpful Links
