CCE Cluster Autoscaler
Introduction
The CCE Cluster Autoscaler add-on is built on the Autoscaler component of the community. It can automatically adjust the number of cluster nodes based on the resource needs of applications, optimizing resource utilization and performance. Autoscaler is the main controller in Kubernetes. It can automatically scale nodes in or out based on resource requirements. When there are not enough node resources to schedule pods in a cluster, Autoscaler adds more nodes with additional resources for those pods. Furthermore, if the resource utilization of the added nodes is low, Autoscaler will automatically remove them. For details about how to implement node auto scaling, see Creating a Node Scaling Policy.
Open source community: https://github.com/kubernetes/autoscaler
How the Add-on Works
Autoscaler controls auto scale-out and scale-in.
- Auto scale-out
You can choose either of the following methods:
- If a pod cannot be scheduled due to insufficient resources of worker nodes, CCE will add more nodes to the cluster. The new nodes have the same resource quotas as those configured for the node pools that the new nodes are in.
Auto scale-out will be performed when:
- Node resources are insufficient.
- No node affinity policy is set in the scheduling configurations of the pod. If the pod is configured affinity for a node, the system will not automatically add more nodes in the cluster. For details about how to configure node affinity policies, see Configuring Node Affinity Scheduling (nodeAffinity).
- When the cluster meets the node scaling policy, cluster scale-out is also triggered. For details, see Creating a Node Scaling Policy.
The add-on follows the "No Less, No More" policy. For example, if three cores are required for creating a pod and the system supports four-core and eight-core nodes, Autoscaler will preferentially create a four-core node.
- Auto scale-in
When a cluster node is idle for a period of time (10 minutes by default), cluster scale-in is triggered, and the node is automatically deleted. However, a node cannot be deleted from a cluster if the following pods exist:
- Pods that do not meet specific requirements set in Pod Disruption Budgets (PodDisruptionBudget)
- Pods that cannot be scheduled to other nodes due to constraints such as affinity and anti-affinity policies
- Pods that have the cluster-autoscaler.kubernetes.io/safe-to-evict: 'false' annotation
- Pods (except those created by DaemonSets in the kube-system namespace) that exist in the kube-system namespace on the node
- Pods that are not created by the controller (Deployment/ReplicaSet/job/StatefulSet)
When a node meets the scale-in conditions, Autoscaler adds the DeletionCandidateOfClusterAutoscaler taint to the node in advance to prevent pods from being scheduled to the node. After the Autoscaler add-on is uninstalled, if the taint still exists on the node, manually delete it.
Notes and Constraints
- There must be enough resources in the cluster during the add-on installation.
- This add-on supports VMs only.
- The default node pool does not support auto scaling. For details, see Description of DefaultPool.
- Node scale-in will cause PVC/PV data loss for the local PVs associated with the node. These PVCs and PVs cannot be restored or used again. In a node scale-in, a pod that uses the local PV will be evicted from the node. A new pod will be created, but it remains in a pending state because the label of the PVC bound to it conflicts with the node label.
- When CCE Cluster Autoscaler is used, some taints or annotations may affect auto scaling. Therefore, do not use the following taints or annotations in clusters:
- ignore-taint.cluster-autoscaler.kubernetes.io: The taint works on nodes. Kubernetes-native Autoscaler supports protection against abnormal scale-outs and periodically evaluates the proportion of available nodes in the cluster. When the proportion of non-ready nodes exceeds 45%, protection will be triggered. In this case, all nodes with the ignore-taint.cluster-autoscaler.kubernetes.io taint in the cluster are filtered out from the Autoscaler template and recorded as non-ready nodes, which affect cluster scaling.
- cluster-autoscaler.kubernetes.io/enable-ds-eviction: The annotation works on pods, which determines whether DaemonSet pods can be evicted by Autoscaler. For details, see Well-Known Labels, Annotations and Taints.
Installing the Add-on
- Log in to the CCE console and click the cluster name to access the cluster console. In the navigation pane, choose Add-ons, locate CCE Cluster Autoscaler on the right, and click Install.
- On the Install Add-on page, configure the specifications as needed.
There are three types of preset specifications based on the cluster scale. You can select one as required. The system will configure the number of pods and resource quotas for the add-on based on the selected preset specifications. You can see the configurations on the console.
- Configure deployment policies for the add-on pods.
- Scheduling policies do not take effect on add-on pods of the DaemonSet type.
- When configuring multi-AZ deployment or node affinity, ensure that there are nodes meeting the scheduling policy and that resources are sufficient in the cluster. Otherwise, the add-on cannot run.
Table 1 Configurations for add-on scheduling Parameter
Multi-AZ Deployment
- Preferred: Deployment pods of the add-on will be preferentially scheduled to nodes in different AZs. If all the nodes in the cluster are deployed in the same AZ, the pods will be scheduled to different nodes in that AZ.
- Equivalent mode: Deployment pods of the add-on are evenly scheduled to the nodes in the cluster in each AZ. If a new AZ is added, you are advised to increase add-on pods for cross-AZ HA deployment. With the Equivalent multi-AZ deployment, the difference between the number of add-on pods in different AZs will be less than or equal to 1. If resources in one of the AZs are insufficient, pods cannot be scheduled to that AZ.
- Forcible: Deployment pods of the add-on are forcibly scheduled to nodes in different AZs. There can be at most one pod in each AZ. If nodes in a cluster are not in different AZs, some add-on pods cannot run properly. If a node is faulty, add-on pods on it may fail to be migrated.
Node Affinity
- Not configured: Node affinity is disabled for the add-on.
- Specify node: Specify the nodes where the add-on is deployed. If you do not specify the nodes, the add-on will be randomly scheduled based on the default cluster scheduling policy.
- Specify node pool: Specify the node pool where the add-on is deployed. If you do not specify the node pools, the add-on will be randomly scheduled based on the default cluster scheduling policy.
- Customize affinity: Enter the labels of the nodes where the add-on is to be deployed for more flexible scheduling policies. If you do not specify node labels, the add-on will be randomly scheduled based on the default cluster scheduling policy.
Toleration
Using both taints and tolerations allows (not forcibly) the add-on Deployment to be scheduled to a node with the matching taints, and controls the Deployment eviction policies after the node where the Deployment is located is tainted.
The add-on adds the default tolerance policy for the node.kubernetes.io/not-ready and node.kubernetes.io/unreachable taints, respectively. The tolerance time window is 60s.
For details, see Configuring Tolerance Policies.
- After the configuration is complete, click Install.
Components
Component |
Description |
Resource Type |
Autoscaler |
Auto scaling for Kubernetes clusters |
Deployment |
Change History
Add-on Version |
Supported Cluster Version |
New Feature |
Community Version |
1.31.8 |
v1.31 |
CCE clusters 1.31 are supported. |
Add-on Version |
New Feature |
Community Version |
1.30.46 |
v1.30 |
Fixed some issues. |
1.30.19 |
v1.30 |
1.30.18 |
v1.30 |
1.30.15 |
v1.30 |
Add-on Version |
New Feature |
Community Version |
1.29.79 |
v1.29 |
1.29.54 |
v1.29 |
1.29.53 |
v1.29 |
1.29.50 |
v1.29 |
Included the name of the target node pool to the reported event. |
1.29.17 |
v1.29 |
Optimized events. |
1.29.13 |
v1.29 |
Clusters 1.29 are supported. |
Add-on Version |
New Feature |
Community Version |
1.28.118 |
v1.28 |
1.28.93 |
v1.28 |
1.28.92 |
v1.28 |
1.28.91 |
v1.28 |
1.28.88 |
v1.28 |
1.28.55 |
v1.28 |
Optimized events. |
1.28.51 |
v1.28 |
Optimized the logic for generating alarms when resources in a bode pool are sold out. |
1.28.22 |
v1.28 |
1.28.20 |
v1.28 |
1.28.17 |
v1.28 |
Fixed the issue that scale-in cannot be performed when there are custom pod controllers in a cluster. |
Add-on Version |
New Feature |
Community Version |
1.27.149 |
v1.27 |
1.27.124 |
v1.27 |
1.27.123 |
v1.27 |
1.27.122 |
v1.27 |
1.27.119 |
v1.27 |
1.27.88 |
v1.27 |
Optimized events. |
1.27.84 |
v1.27 |
1.27.55 |
v1.27 |
1.27.53 |
v1.27 |
1.27.51 |
v1.27 |
1.27.14 |
v1.27 |
Fixed the scale-in failure of nodes of different specifications in the same node pool and unexpected PreferNoSchedule taint issues. |
Add-on Version |
New Feature |
Community Version |
1.25.179 |
v1.25 |
1.25.154 |
v1.25 |
1.25.153 |
v1.25 |
1.25.152 |
v1.25 |
1.25.120 |
v1.25 |
Optimized events. |
1.25.116 |
v1.25 |
1.25.88 |
v1.25 |
1.25.86 |
v1.25 |
1.25.84 |
v1.25 |
1.25.46 |
v1.25 |
1.25.34 |
v1.25 |
1.25.21 |
v1.25 |
1.25.11 |
v1.25 |
1.25.7 |
v1.25 |
Add-on Version |
New Feature |
Community Version |
1.23.159 |
v1.23 |
1.23.157 |
v1.23 |
1.23.156 |
v1.23 |
1.23.125 |
v1.23 |
Optimized events. |
1.23.121 |
1.23 |
1.23.95 |
v1.23 |
1.23.93 |
v1.23 |
1.23.91 |
v1.23 |
1.23.54 |
v1.23 |
1.23.44 |
v1.23 |
1.23.31 |
v1.23 |
1.23.21 |
v1.23 |
1.23.17 |
v1.23 |
1.23.10 |
v1.23 |
1.23.9 |
v1.23 |
Added the nodenetworkconfigs.crd.yangtse.cni resource object permission. |
1.23.8 |
v1.23 |
Fixed the issue that scale-out fails when the number of nodes to be added at a time exceeds the upper limit in periodic scale-outs. |
1.23.7 |
v1.23 |
1.23.3 |
v1.23 |
CCE clusters 1.23 are supported. |
Add-on Version |
New Feature |
Community Version |
1.21.114 |
v1.21 |
1.21.89 |
v1.21 |
1.21.87 |
v1.21 |
1.21.86 |
v1.21 |
Fixed the issue that the node pool auto scaling cannot meet expectations after AZ topology constraints are configured for nodes. |
1.21.51 |
v1.21 |
1.21.43 |
v1.21 |
1.21.29 |
v1.21 |
1.21.20 |
v1.21 |
1.21.16 |
v1.21 |
1.21.9 |
v1.21 |
1.21.8 |
v1.21 |
1.21.6 |
v1.21 |
Fixed the issue that authentication fails due to incorrect signature in the add-on request retries. |
1.21.4 |
v1.21 |
1.21.2 |
v1.21 |
Fixed the issue that auto scaling may be blocked due to a failure in deleting an unregistered node. |
1.21.1 |
v1.21 |
Fixed the issue that the node pool modification in the existing periodic auto scaling rule does not take effect. |
Add-on Version |
New Feature |
Community Version |
1.19.76 |
v1.19 |
1.19.56 |
v1.19 |
1.19.48 |
v1.19 |
1.19.35 |
v1.19 |
1.19.27 |
v1.19 |
1.19.22 |
v1.19 |
1.19.14 |
v1.19 |
1.19.13 |
v1.19 |
1.19.12 |
v1.19 |
1.19.11 |
v1.19 |
1.19.9 |
v1.19 |
1.19.8 |
v1.19 |
1.19.7 |
v1.19 |
Regular upgrade of add-on dependencies |
1.19.6 |
v1.19 |
Fixed the issue that repeated scale-out is triggered when taints are asynchronously updated. |
1.19.3 |
v1.19 |
Supports scheduled scaling policies based on the total number of nodes, CPU limit, and memory limit. Fixes other functional defects. |
Add-on Version |
New Feature |
Community Version |
1.17.27 |
v1.17 |
1.17.22 |
v1.17 |
Optimized logging. |
1.17.21 |
v1.17 |
1.17.19 |
v1.17 |
1.17.17 |
v1.17 |
1.17.16 |
v1.17 |
1.17.15 |
v1.17 |
Unified resource specification configuration unit. |
1.17.14 |
v1.17 |
1.17.8 |
v1.17 |
Fixed bugs. |
1.17.7 |
v1.17 |
Added log content and fixed bugs. |
1.17.5 |
v1.17 |
Supported clusters 1.17 and allowed scaling events to be displayed on the CCE console. |
1.17.2 |
v1.17 |
Clusters 1.17 are supported. |
Change History
Add-on Version |
New Feature |
Community Version |
1.31.8 |
v1.31 |
Add-on Version |
New Feature |
Community Version |
1.28.118 |
v1.28 |
1.28.88 |
v1.28 |
The reported event includes the name of the target node pool. |
1.28.55 |
v1.28 |
None |
1.28.20 |
v1.28 |
None |
Add-on Version |
New Feature |
Community Version |
1.25.179 |
v1.25 |
1.25.152 |
v1.25 |
1.25.120 |
v1.25 |
None |
1.25.86 |
v1.25 |
1.25.21 |
v1.25 |
Add-on Version |
New Feature |
Community Version |
1.23.156 |
v1.23 |
1.23.125 |
v1.23 |
None |
1.23.31 |
v1.23 |
1.23.17 |
v1.23 |
Add-on Version |
New Feature |
Community Version |
1.21.16 |
v1.21 |
Add-on Version |
New Feature |
Community Version |
1.19.22 |
v1.19 |
