Updated on 2026-08-13 GMT+08:00
CCE Container Storage (Everest)
Introduction
Container Storage Interface (CSI) is a storage add-on standard recommended by the Kubernetes community. It is used for unified interconnection between the container orchestration platform and various storage systems. Based on the CSI standard, CCE provides CCE Container Storage (Everest), a self-developed storage add-on. This add-on can seamlessly interconnect with multiple IaaS storage services, including EVS (block storage), SFS, SFS Turbo, and OBS to provide multiple types of persistent storage capabilities for containers.
CCE Container Storage (Everest) provides diverse persistent storage capabilities for clusters. It can adapt to storage requirements in various service scenarios, such as databases, high-performance computing, shared file access, and large file archiving. This add-on provides a unified storage interface, supports multiple types of storage media, and works closely with CCE scheduling policies, auto scaling strategies, and security systems. It can significantly improve the storage performance and service continuity of cloud native workloads.
CCE Container Storage (Everest) is a system resource add-on. It is installed by default when a cluster of Kubernetes v1.15 or later is created.
  • In CCE Container Storage 1.2.0, key authentication is optimized when OBS is used. After the add-on is upgraded from a version earlier than 1.2.0, restart all workloads that use OBS in the cluster. Otherwise, workloads may not be able to use OBS.
  • Nodes running Huawei Cloud EulerOS 1.1 support CCE Container Storage (Everest) of 2.x.x (2.1.9 or later) and 1.2.x (1.2.70 or later), but do not support the add-on of 1.3.x.
Installing the Add-on
This add-on is installed by default. If it is uninstalled due to some reasons, you can reinstall it by performing the following steps:
  2. In the navigation pane, choose Add-ons. Locate CCE Container Storage (Everest) and click Edit.
  3. On the Install Add-on page, configure the specifications as needed.
    • If you selected Preset, you can choose among Small, Medium, and Large specifications according to your workload requirements. The system automatically configures the number of add-on pods and their resource quotas based on your selected preset. You can review these configurations on the console.
      The small specification is best for clusters with up to 50 nodes and 500 PVCs. The medium specification works well for clusters with up to 200 nodes and 2000 PVCs. The large specification is perfect for clusters with up to 1000 nodes and 10,000 PVCs.
    • If you selected Custom, you can adjust the number of pods and resource quotas as needed. The requested CPUs and memory can be adjusted based on the number of nodes and PVCs. For details, see Table 1.
      In non-typical scenarios, the formulas for estimating the limits are as follows:
      • everest-csi-controller
        • CPU limit: 250m for 200 or fewer nodes, 350m for 1000 nodes, and 500m for 2000 nodes
        • Memory limit = (200 MiB + Number of nodes × 1 MiB + Number of PVCs × 0.2 MiB) × 1.2
      • everest-csi-driver
        • CPU limit: 300m for 200 or fewer nodes, 500m for 1000 nodes, and 800m for 2000 nodes
        • Memory limit: 300 MiB for 200 or fewer nodes, 600 MiB for 1000 nodes, and 900 MiB for 2000 nodes
      Table 1 Recommended configuration limits in typical scenarios
      Configuration Scenario
      everest-csi-driver
      Nodes
      PVs/PVCs
      Add-on Pods
      CPU Cores (Limit = Request)
      Memory (Limit = Request)
      50
      1000
      2
      250m
      600 MiB
      300m
      300 MiB
      200
      1000
      2
      250m
      1 GiB
      300m
      300 MiB
      1000
      1000
      2
      350m
      2 GiB
      500m
      600 MiB
      1000
      5000
      2
      450m
      3 GiB
      500m
      600 MiB
      2000
      5000
      2
      550m
      4 GiB
      800m
      900 MiB
      2000
      10000
      2
      650m
      5 GiB
      800m
      900 MiB
  4. Configure Agency Settings. This configuration is supported by the add-on of 2.5.1 or later.
    Add-ons require runtime access to other cloud services. You need to configure an add-on agency to authorize these operations. For details, see Custom Agencies for Add-ons.
    • Create automatically: CCE automatically creates a default agency and uses this agency for the add-on. If there is a default agency, CCE will not create one again.
    • Use existing: Select one from the drop-down list. Ensure that the created agency has been assigned the required permissions. Otherwise, the add-on functions may be unavailable.
  5. Configure the add-on parameters.
    Table 2 Add-on parameters
    Item
    Configuration Method
    Reserved EVS Disks for Non-Container Workloads
    Using the GUI
    Number of disks on the node reserved for custom use. This parameter is supported when the add-on version is 2.3.11 or later.
    Assume that a maximum of 20 EVS disks can be attached to a node, and the value of this parameter is set to 6. Then 14 (20-6) disks are available on this node for scheduling workloads with EVS disks attached. The reserved six disks include one system disk and one data disk that are already attached to the node. You can attach four EVS disks to this node as additional data disks or raw disks for use in a local storage pool.
    Prohibit Global Secret from Mounting Object Storage
    Using the GUI
    Whether the default AK/SK can be used when an OBS bucket or parallel file system is mounted.
    • is: If you do not specify a custom secret for mounting an OBS PVC, the global secret you uploaded will be used.
    • No: If you do not specify a custom secret for mounting an OBS PVC, only the global secret you uploaded can be used. Otherwise, the mounting will fail.
    Concurrent EVS Disk Attaching Tasks
    Using the GUI
    Number of workers that can be concurrently processed by CCE Container Storage (Everest) for attaching EVS volumes. The default value is 60.
    Concurrent EVS Disk Detaching Tasks
    Using the GUI
    Number of workers that can be concurrently processed by CCE Container Storage (Everest) for detaching EVS volumes. The default value is 60.
    Distributed Volume Mounting
    Using the GUI
    If enabled, the everest-csi-driver component on each node is responsible for attaching or detaching EVS disks.
    If disabled, the everest-csi-controller component takes on this responsibility.
    flow_control
    Using extended parameters
    The default API client flow control configuration is used. After installing the CCE Container Storage (Everest) add-on, you can refer to ConfigMap everest-driver-th-config in the kube-system namespace for more details.
    over_subscription
    Overcommitment ratio of a local storage pool (local_storage). The default value is 80. If the pool size is 100 GiB, it can be overcommitted up to 180 GiB. (Total capacity after overcommitment = (1 + Overcommitment ratio) × Actual capacity)
    enable_local_autoexpander
    Whether to enable automatic capacity expansion for a local storage pool of thin volumes. If this function is enabled, automatic capacity expansion is triggered based on the expansion threshold and step of the local storage pool.
    expansion_threshold
    Capacity expansion threshold of a local storage pool of thin volumes. If the storage pool usage exceeds the threshold, its capacity will be automatically expanded.
    expansion_step
    Capacity expansion step of a single EVS disk in a local storage pool of thin volumes (unit: Gi).
    expansion_max_evs_size
    Maximum capacity of a single EVS disk in a local storage pool of thin volumes (unit: Gi).
    volume_attaching_flow_ctrl
    Maximum number of EVS volumes that can be attached by the CCE Container Storage (Everest) add-on within 1 minute. The default value is 0, indicating that there is no limit on the number of EVS volumes and the performance of attaching EVS volumes is determined by the underlying storage resources.
    enable_aksk_refresh
    Whether to enable the function of dynamically updating custom access keys (AK/SK) using object storage. This parameter is supported when the add-on version is 2.4.150 or later. For details, see Automatically Applying Updated Access Keys (AK/SK) for an OBS Volume. The default value is false, indicating that the function is disabled. The value true indicates that the function is enabled.
    If the add-on version is between 2.4.150 (inclusive) and 2.4.165 (exclusive), only parallel file systems are supported. Starting from version 2.4.165 and onward, both parallel file systems and OBS buckets are supported.
    In the extended parameter settings, you can customize the advanced settings that are not displayed on the GUI. If the settings in the extended parameters conflict with those on the GUI, the settings in the extended parameters will work.
  6. Configure deployment policies for the add-on pods.
    • Scheduling policies do not take effect on the DaemonSet pods of the add-on.
    • When configuring multi-AZ deployment or node affinity, ensure that there are nodes meeting the scheduling policy and that resources are sufficient in the cluster. Otherwise, the add-on pods cannot run.
    Table 3 Configurations for add-on scheduling
    Multi-AZ Deployment
    • Preferred: Deployment pods of the add-on will be preferentially scheduled to nodes in different AZs. If all the nodes in the cluster are deployed in the same AZ, the pods will be scheduled to different nodes in that AZ.
    • Equivalent mode: Deployment pods of the add-on are evenly scheduled to the nodes in the cluster in each AZ. If a new AZ is added, you are advised to increase add-on pods for cross-AZ HA deployment. With the Equivalent multi-AZ deployment, the difference between the number of add-on pods in different AZs will be less than or equal to 1. If resources in one of the AZs are insufficient, pods cannot be scheduled to that AZ.
    • Forcible: Deployment pods of the add-on are forcibly scheduled to nodes in different AZs. There can be at most one pod in each AZ. If nodes in a cluster are not in different AZs, some add-on pods cannot run properly. If a node is faulty, the add-on pods on it may fail to be migrated.
    Node Affinity
    • Not configured: Node affinity is disabled for the add-on pods.
    • Specify node: Specify the nodes where the add-on pods are deployed. If you do not specify the nodes, the add-on pods will be randomly scheduled based on the default cluster scheduling policy.
    • Specify node pool: Specify the node pool where the add-on pods are deployed. If you do not specify the node pools, the add-on pods will be randomly scheduled based on the default cluster scheduling policy.
    • Customize affinity: Enter the labels of the nodes where the add-on pods are to be deployed for more flexible scheduling policies. If you do not specify node labels, the add-on pods will be randomly scheduled based on the default cluster scheduling policy.
      If multiple custom affinity policies are configured, ensure that there are nodes that meet all the affinity policies in the cluster. Otherwise, the add-on pods cannot run.
    Toleration
    Using both taints and tolerations enables (but does not require) the add-on's Deployment pods to be scheduled on nodes with matching taints, and allows control over pod eviction policies when host nodes are tainted.
    The add-on applies default tolerations for the node.kubernetes.io/not-ready and node.kubernetes.io/unreachable taints. The toleration time window is 60 seconds.
    For details, see Configuring Tolerance Policies.
  7. Click Install.
Components
Table 4 Add-on components
Component
Resource Type
Used to create, delete, expand, attach, detach, and take snapshots for PVs. If the cluster version is 1.19 or later and the add-on version is 1.2.x, the pod of the everest-csi-controller component also has an everest-localvolume-manager container by default. This container manages the creation of LVM storage pools and local PVs on nodes.
Deployment
everest-csi-driver
Used to mount and unmount PVs and resize file systems. If the add-on version is 1.2.x and the region where the cluster is located supports node-attacher, the pod of the everest-csi-driver component contains an everest-node-attacher container. This container is responsible for distributed EVS attaching. This configuration is available in some regions.
DaemonSet
Collecting Prometheus Metrics
everest-csi-controller exposes Prometheus metrics over port 3225. You can create an on-premises Prometheus collector to identify and obtain everest-csi-controller metrics from http://{{everest-csi-controller pod IP address}}:3225/metrics.
Prometheus metrics can be exposed only when the CCE Container Storage (Everest) add-on version is 2.4.4 or later.
Table 5 Key metrics
Metric
Type
Label
Example
everest_action_result_total
Counter
Invocation of different functions
action: indicates different functions. For details, see Table 6.
result: indicates that the invocation succeeds or fails.
everest_action_result_total{action="create_snapshot:disk.csi.everest.io",result="success"} 2
everest_function_duration_seconds_bucket
Histogram
Number of times that different functions are executed at different times
function: indicates different functions. For details, see Table 6.
everest_function_duration_seconds_bucket{function="create_snapshot:disk.csi.everest.io",le="10"} 2
everest_function_duration_seconds_sum
Histogram
Total invocation time for different functions
everest_function_duration_seconds_sum{function="create:disk.csi.everest.io"} 24.381399053
everest_function_duration_seconds_count
Histogram
Number of invocation times of different functions
everest_function_duration_seconds_count{function="attach:disk.csi.everest.io"} 4
action and function specify different CSI drivers and their functions, and are in the format of {Function}:{CSI driver}. For example, create:disk.csi.everest.io specifies that the function is to create a volume and the volume type is EVS disk.
Table 6 Functions
Operation
create
Create a volume.
delete
Delete a volume.
attach
Mount a volume.
detach
Unmount a volume.
expand
Expand the capacity of a volume.
create_snapshot
Create a volume snapshot.
delete_snapshot
Delete a volume snapshot
Release History
Table 7 CCE Container Storage (Everest) updates
Add-on Version
Supported Cluster Version
New Feature
2.5.66
v1.29
v1.30
v1.31
v1.32
v1.33
v1.34
v1.35
v1.36
Fixed some issues.
2.5.51
v1.29
v1.30
v1.31
v1.32
v1.33
v1.34
v1.35
v1.36
Supported CCE clusters v1.36.
2.5.41
v1.29
v1.30
v1.31
v1.32
v1.33
v1.34
v1.35
Fixed some issues.
2.5.28
v1.29
v1.30
v1.31
v1.32
v1.33
v1.34
v1.35
Supported CCE clusters v1.35.
2.5.16
v1.28
v1.29
v1.30
v1.31
v1.32
v1.33
v1.34
Fixed some issues.
2.5.6
v1.28
v1.29
v1.30
v1.31
v1.32
v1.33
v1.34
  • Supported obtaining IAM credentials using pod identities.
  • Supported custom agencies.
2.4.209
v1.28
v1.29
v1.30
v1.31
v1.32
v1.33
v1.34
Supported CCE clusters v1.34.
2.4.197
v1.27
v1.28
v1.29
v1.30
v1.31
v1.32
v1.33
Fixed some issues.
2.4.196
v1.27
v1.28
v1.29
v1.30
v1.31
v1.32
v1.33
Fixed some issues.
2.4.183
v1.27
v1.28
v1.29
v1.30
v1.31
v1.32
v1.33
Supported CCE clusters v1.33.
2.4.169
v1.27
v1.28
v1.29
v1.30
v1.31
v1.32
Optimized the performance in large-scale disk mounting scenarios.
2.4.161
v1.25
v1.27
v1.28
v1.29
v1.30
v1.31
v1.32
Supported CCE clusters v1.32.
2.4.134
v1.25
v1.27
v1.28
v1.29
v1.30
v1.31
Fixed some issues.
2.4.111
v1.25
v1.27
v1.28
v1.29
v1.30
v1.31
Fixed some issues.
2.4.105
v1.25
v1.27
v1.28
v1.29
v1.30
v1.31
Supported CCE clusters v1.31.
2.4.75
v1.23
v1.25
v1.27
v1.28
v1.29
v1.30
Fixed some issues.
2.4.72
v1.23
v1.25
v1.27
v1.28
v1.29
v1.30
Supported CCE clusters v1.30.
2.4.44
v1.23
v1.25
v1.27
v1.28
v1.29
  • Subdirectories can be created in an SFS 3.0 file system.
  • The usage of storage volumes can be obtained.
2.4.28
v1.23
v1.25
v1.27
v1.28
v1.29
Fixed some issues.
2.4.21
v1.23
v1.25
v1.27
v1.28
v1.29
  • Supported OBS multi-AZ storage redundancy policy.
  • The prefixes of storage volume names can be customized.
  • Supported yearly/monthly EVS disks.
2.4.8
v1.21
v1.23
v1.25
v1.27
v1.28
v1.29
  • Supported CCE clusters v1.29.
  • Supported GPSSD2 disks.
  • Supported DSS. The cluster version must be v1.21.15-r0, v1.23.14-r0, v1.25.9-r0, v1.27.6-r0, v1.28.4-r0, or later.
2.3.23
v1.21
v1.23
v1.25
v1.27
v1.28
Subdirectories can be created in an SFS Turbo file system.
2.3.21
v1.21
v1.23
v1.25
v1.27
v1.28
Fixed some issues.
2.3.14
v1.21
v1.23
v1.25
v1.27
v1.28
Supported CCE clusters v1.28.
2.1.51
v1.19
v1.21
v1.23
v1.25
v1.27
Supported Huawei Cloud EulerOS 2.0.
2.1.30
v1.19
v1.21
v1.23
v1.25
  • Supported anti-affinity scheduling of add-on pods on nodes in different AZs.
  • Adapted the obsfs package to Ubuntu 22.04.
2.1.13
v1.19
v1.21
v1.23
v1.25
Optimized the performance of creating subPath PVCs in batches for SFS Turbo volumes.
2.1.9
v1.19
v1.21
v1.23
v1.25
  • Supported graceful exit of the controller.
  • Supported CCE clusters v1.25.
2.0.9
v1.19
v1.21
v1.23
  • Rebuilt certain code and architecture of everest to improve its scalability and stability.
  • Enabled graceful exit.
  • Supported OBS process monitoring.
1.3.28
v1.19
v1.21
v1.23
1.3.22
v1.19
v1.21
v1.23
Handled occasional read and write failures after repeated disk mounting.
1.3.20
v1.19
v1.21
v1.23
1.3.17
v1.19
v1.21
v1.23
  • Changed the maximum number of unavailable everest-csi-driver pods during a rolling update from 10 to 10%.
  • Supported custom pod anti-affinity rules.
  • Counted the maximum number of SCSI volumes that can be managed by the CSI add-on on a node.
  • Drivers can be deployed based on custom resource specifications.
1.3.8
v1.23
Supported CCE clusters v1.23.
1.3.6
v1.23
1.2.78
v1.15
v1.17
v1.19
v1.21
1.2.70
v1.15
v1.17
v1.19
v1.21
1.2.67
v1.15
v1.17
v1.19
v1.21
1.2.61
v1.15
v1.17
v1.19
v1.21
1.2.55
v1.15
v1.17
v1.19
v1.21
1.2.53
v1.15
v1.17
v1.19
v1.21
1.2.51
v1.15
v1.17
v1.19
v1.21
1.2.44
v1.15
v1.17
v1.19
v1.21
  • Enterprise projects can be selected for EVS and OBS volumes.
  • By default, the enable_noobj_cache parameter is no longer used for mounting OBS buckets.
1.2.42
v1.15
v1.17
v1.19
v1.21
1.2.30
v1.15
v1.17
v1.19
v1.21
Supported emptyDir.
1.2.28
v1.15
v1.17
v1.19
v1.21
Supported CCE clusters v1.21.
1.2.27
v1.15
v1.17
v1.19
v1.21
Supported extreme SSD (ESSD) and general-purpose SSD (GPSSD) EVS disks.
1.2.13
v1.15
v1.17
v1.19
Supported EulerOS 2.10.
1.2.9
v1.15
v1.17
v1.19
  • Enhanced the reliability of PV lifecycle maintenance.
  • The Attach/Detach Controller can be used to attach or detach volumes in clusters v1.19.10.
  • Improved SFS mounting stability.
  • Changed the default EVS creation type of a new cluster to SAS.
1.2.5
v1.15
v1.17
v1.19
  • Improved the reliability of mounting-related capabilities.
  • Optimized the authentication function for using OBS, which requires you to upload the access key.
  • Improved the compatibility of the everest add-on with FlexVolume volumes.
  • Improved running stability of the add-on.
1.1.12
v1.15
v1.17
Enhanced the reliability of the everest-csi-controller component.
1.1.11
v1.15
v1.17
  • Supported security hardening.
  • Supported third-party OBS storage.
  • Switched to the EVS query API with better performance.
  • Disks can be created from snapshots using cloning by default.
  • Optimized and enhanced disk status detection and log output for attaching and detaching operations.
  • Improved the reliability of determining authentication expiration.
1.1.8
v1.15
v1.17
Supported CCE v1.17. During the upgrades of CCE v1.13 to v1.15, CCE Container Storage (Everest) will take over all functions of FlexVolume.
1.1.7
v1.15
v1.17
