Expanding the Capacity of an EVS Volume
If the EVS volume mounted to a workload does not have enough space, you can increase its capacity by expanding it. This section describes how to expand the capacity of an EVS volume through the console.
You have created a cluster of v1.27.8-r0, v1.28.6-r0, or later.
- In the navigation pane, choose Storage. Then click the PVCs tab. Locate the target PVC and click More > Scale-out in the Operation column.
Figure 1 Expanding the capacity of an EVS volume
- Enter the capacity to be added and click OK. In this example, 10 GiB is added.
The capacity can only be increased.
Figure 2 Configuring the capacity to be expanded - Verify that the expansion is successful. On the PVCs tab, you can see that the PVC capacity is expanded from 10 GiB to 20 GiB.
