Help Center/ Cloud Container Engine_Autopilot/ User Guide/ Storage/ EVS Volumes/ Dynamically Mounting an EVS Volume to a StatefulSet
Updated on 2026-09-18 GMT+08:00
Dynamic mounting is only available for creating a StatefulSet. It is implemented through a volume claim template (the volumeClaimTemplates field) and depends on dynamic creation of PVs through StorageClass. In this mode, each pod in a multi-pod StatefulSet is associated with a unique PVC and PV. After a pod is rescheduled, the original PV can still be mounted to it based on the PVC name. In the common mounting mode for a Deployment, if ReadWriteMany is supported, multiple pods of the Deployment will be mounted to the same underlying storage.
When updating a StatefulSet in Kubernetes, it is not allowed to add or delete the volumeClaimTemplates field. This field can only be configured during the creation of the StatefulSet.
  • Not all regions support EVS volumes. View the regions where EVS volumes are supported on the console.
  • The cluster version must be v1.27.8-r0, v1.28.6-r0, or later. If the cluster version does not meet the requirements, you need to upgrade the cluster.
  • No more than 10 EVS disks can be attached to each workload in a cluster. If more than 10 EVS disks are attached, the workload may run abnormally.
Dynamically Creating and Mounting an EVS Volume
By specifying the StorageClass, you can create a unique PVC and PV for each pod of a StatefulSet on the console or using kubectl to ensure data durability after rescheduling.
Dynamically mount and use storage volumes. For details about other parameters, see Creating a StatefulSet.
  1. Log in to the CCE console and click the cluster name to go to the cluster console.
  2. In the navigation pane, choose Workloads. Then click the StatefulSets tab.
  3. Click Create Workload in the upper right corner. On the displayed page, click Data Storage in the Container Settings area and click Add Volume to select VolumeClaimTemplate.
  4. In the upper right corner, click Create PVC. In the displayed dialog box, configure the parameters.
    Click Create.
    Figure 1 Creating a PVC
    PVC Type
    In this example, select EVS.
    PVC Name
    Enter the name of the PVC. After a PVC is created, a suffix is automatically added based on the number of pods. The format is <Custom PVC name>-<Serial number>, for example, example-0.
    Namespace
    A namespace is a logical construct that organizes and isolates resources within a Kubernetes cluster. Resources in different namespaces are isolated from each other. You can create namespaces as needed.
    After a cluster is created, the default namespace is created by default. If there is no special requirement, select the default namespace.
    Creation Method
    You can select Dynamically provision to create a PVC, PV, and underlying storage on the console in cascading mode.
    Storage Classes
    The StorageClass for EVS volumes is csi-disk.
    (Optional) PV Name Prefix
    This parameter specifies the name of the underlying storage that is automatically created. The actual underlying storage name is in the format of "PV name prefix + PVC UID". If this parameter is left blank, the default prefix pvc will be used.
    For example, if the storage volume name prefix is set to test, the actual underlying storage name is test-{UID}.
    AZ
    Select the AZ of the EVS disk. After the EVS disk is created, the AZ cannot be changed.
    In this example, select AZ3.
    Disk Type
    Select an EVS disk type. EVS disk types vary depending on regions. Obtain the available EVS types on the console.
    In this example, select High I/O.
    General-purpose SSD V2 disks allow you to specify the disk IOPS and throughput. For details, see EVS performance data.
    Capacity (GiB)
    Capacity of the requested storage volume.
    Set it to 10 in this example.
    Access Mode
    EVS volumes support only ReadWriteOnce, meaning a volume can be mounted in read/write mode. For details, see Volume Access Modes.
    Encryption
    Configure whether to encrypt underlying storage. If you select Enabled (key), an encryption key must be configured. Currently, encryption is not supported.
    Enterprise Project
    This parameter is only available for enterprise accounts with enterprise projects enabled. The enterprise project can be the default project, the project where the cluster is located, or the project specified by the StorageClass.
    Resource Tag
    You can add resource tags to classify resources.
    You can create predefined tags on the TMS console. The predefined tags are available to all resources that support tags. You can use predefined tags to improve the tag creation and resource migration efficiency. For details, see Creating Predefined Tags.
    CCE automatically creates system tags CCE-Cluster-ID={cluster-ID}, CCE-Cluster-Name={cluster-name}, and CCE-Namespace={namespace-name}. These tags cannot be modified.
    After a dynamic PV of the EVS type is created, the resource tags cannot be updated on the CCE console. To update these resource tags, go to the EVS console.
  5. Enter the path to which the volume is mounted.
    In this example, the volume is mounted to the /data path of the container. The container data generated in this path is stored in the EVS disk.
    Figure 2 Parameters for mounting a storage volume
    Table 1 Parameters for mounting a storage volume
    Mount Path
    Enter a mount path, for example, /data.
    This parameter indicates the container path that the volume will be mounted to. Do not mount the volume to a system directory such as / or /var/run. This may cause container errors. Mount the volume to an empty directory. If the directory is not empty, ensure that there are no files that affect container startup. If there are such files, they will be replaced, which will lead to a container startup or workload creation failure.
    NOTICE:
    If a volume is mounted to a high-risk directory, use an account with minimum permissions to start the container, or high-risk files on the host may be damaged.
    Subpath
    Enter the subpath of the storage volume and mount a path in the storage volume to the container. In this way, different folders of the same storage volume can be used in a single pod. data, for example, indicates that data in the mount path of the container is stored in the data directory of the storage volume. If this parameter is left blank, the root path is used by default.
    Permission
    • Read-only: You can only read the data in the mounted volume.
    • Read-write: You can modify the volume mounted to the path. Newly written data will not be migrated if the container is migrated, which may cause data loss.
  6. Configure other parameters and click Create Workload. After the workload is created, the data in the container mount directory will be persistently stored. Verify the storage by referring to Verifying Data Persistence.
  1. Use kubectl to connect to the cluster.
  2. Create a file named statefulset-evs.yaml. In this example, the EVS volume is mounted to the /data path.
    apiVersion: apps/v1
    kind: StatefulSet
      namespace: default
      selector:
        matchLabels:
          app: statefulset-evs
      template:
          labels:
          containers:
            - name: container-1
              image: nginx:latest
              volumeMounts:
                - name: pvc-disk           # The name must be the same as that in the volumeClaimTemplates field.
                  mountPath: /data         # Location where the storage volume is mounted
          imagePullSecrets:
            - name: default-secret
      serviceName: statefulset-evs         # Headless Service name
      replicas: 2
      volumeClaimTemplates:
        - apiVersion: v1
          kind: PersistentVolumeClaim
            namespace: default
            annotations:
              everest.io/disk-volume-type: SAS    # EVS disk type
              everest.io/enterprise-project-id: <your_project_id>  # (Optional) Enterprise project ID
              everest.io/disk-iops: '3000'      # (Optional) IOPS of only a GPSSD2 EVS disk
              everest.io/disk-throughput: '125' # (Optional) Throughput of only a GPSSD2 EVS disk
              everest.io/csi.volume-name-prefix: test  # (Optional) Storage volume name prefix of the automatically created underlying storage
            labels:
              failure-domain.beta.kubernetes.io/region: <your_region>   # Replace the region with the one where the cluster is located.
              failure-domain.beta.kubernetes.io/zone: <your_zone>       # Replace the AZ with the one where the EVS disk is located.
            accessModes:
              - ReadWriteOnce               # The value must be ReadWriteOnce for EVS volumes.
            resources:
              requests:
                storage: 10Gi             # EVS disk capacity, in GiB. The value ranges from 1 to 32768.
            storageClassName: csi-disk    # The StorageClass of the EVS disk
    apiVersion: v1
    kind: Service
      name: statefulset-evs   # Headless Service name
      namespace: default
      labels:
      selector:
      clusterIP: None
      ports:
        - name: statefulset-evs
          targetPort: 80
          nodePort: 0
          port: 80
          protocol: TCP
      type: ClusterIP
    Table 2 Key parameters
    Mandatory
    Yes
    Region of the cluster.
    For example, cn-east-3. For details, see Regions and Endpoints.
    Yes
    AZ of the EVS disk.
    You can obtain all supported AZs by querying the AZ list.
    Yes
    EVS disk type. All letters are in uppercase. EVS disk types vary depending on regions. Obtain the available EVS types on the console.
    • SAS: High I/O
    • SSD: Ultra-high I/O
    • GPSSD: General Purpose SSD
    • ESSD: Extreme SSD
    • GPSSD2: General Purpose SSD v2. You need to specify the everest.io/disk-iops and everest.io/disk-throughput annotations.
    No
    Preconfigured IOPS, which is supported only by General Purpose SSD v2 EVS disks.
    • The IOPS of General Purpose SSD v2 disks ranges from 3000 to 128000, and the maximum value is 500 times the capacity (GiB).
      If the IOPS of General Purpose SSD v2 disks is greater than 3000, extra IOPS will be billed. For details, see Price Calculator.
    No
    Preconfigured throughput, which is supported only by General Purpose SSD v2 EVS disks.
    The value ranges from 125 MiB/s to 1,000 MiB/s. The maximum value is a quarter of IOPS.
    If the throughput is greater than 125 MiB/s, extra throughput will be billed. For details, see Price Calculator.
    No
    ID of the enterprise project for the EVS disk. It is only applicable to enterprise accounts with enterprise projects enabled. For more information, see Enterprise Management. If an enterprise project is specified, you must specify the same enterprise project when creating a PVC. Otherwise, the PVC cannot be bound to a PV.
    How to obtain: To obtain an enterprise project ID, log in to the EPS console, click the name of the target enterprise project, and copy the enterprise project ID.
    everest.io/disk-volume-tags
    No
    You can add resource tags to classify resources. This field is optional.
    You can create predefined tags on the TMS console. These tags are available to all resources that support tags. You can use these tags to improve the tag creation and resource migration efficiency. For details, see Creating Predefined Tags.
    No
    This parameter is optional. It specifies the name of the underlying storage that is automatically created. The actual underlying storage name is in the format of "PV name prefix + PVC UID". If this parameter is left blank, the default prefix pvc will be used.
    Enter 1 to 26 characters that cannot start or end with a hyphen (-). Only lowercase letters, digits, and hyphens (-) are allowed.
    storage
    Yes
    Requested PVC capacity, in Gi. The value is an integer from 1 to 32,768.
    If storage is set to a decimal, the value will be rounded up for the EVS disk. For example, if storage is set to 10.1Gi, an 11-GiB EVS disk will be created.
    storageClassName
    Yes
  3. Run the following command to create a workload to which the EVS volume is mounted:
    kubectl apply -f statefulset-evs.yaml
  1. View the deployed application and files stored in the EVS volume.
    1. Run the following command to view the pods:
      kubectl get pod | grep statefulset-evs
      Expected output:
      statefulset-evs-0          1/1     Running   0             45s
      statefulset-evs-1          1/1     Running   0             28s
    2. Run the following command to verify that the EVS volume has been mounted to the /data path:
      kubectl exec statefulset-evs-0 -- df | grep data
      Expected output:
      /dev/sdd              10255636     36888  10202364   0% /data
    3. Run the following command to view the created file in the /data path:
      kubectl exec statefulset-evs-0 -- ls /data
      Expected output:
      lost+found
  2. Run the following command to create a file named static in the /data path:
    kubectl exec statefulset-evs-0 --  touch /data/static
    Expected output:
    lost+found
    static
  4. Run the following command to delete the pod named web-evs-auto-0:
    kubectl delete pod statefulset-evs-0
    Expected output:
    pod "statefulset-evs-0" deleted
  5. The StatefulSet controller automatically creates a replica with the same name as the pod. Run the following command to check whether the file in the /data path has been modified:
    Expected output:
    lost+found
    static
    The static file is retained, indicating that the data can be stored persistently.
Related Operations
You can also perform the operations described in Table 3.
Table 3 Related operations
Operation
Expanding the capacity of an EVS volume
Quickly expand the capacity of a mounted EVS volume on the CCE console.
  1. In the navigation pane, choose Storage. Then click the PVCs tab. Locate the target PVC and choose More > Scale-out in the Operation column.
  2. Enter the capacity to be added and click OK.
Viewing events
You can view event names, event types, number of occurrences, Kubernetes events, first occurrence time, and last occurrence time of the PVC or PV.
  1. In the navigation pane, choose Storage. Then click the PVCs or PVs tab.
  2. Locate the target PVC or PV and click View Events in the Operation column to view the events generated within one hour (events are retained for one hour).
Viewing a YAML file
You can view, copy, and download the YAML files of a PVC or PV.
  2. Locate the target PVC or PV, click View YAML in the Operation column to view or download the YAML.
Editing a reclaim policy
You can modify the reclaim policy of a PV.
  1. In the navigation pane, choose Storage. Then click the PVs tab.
  2. Locate the target PV and choose More > Edit Reclaim Policy to modify the reclaim policy.
Synchronizing capacity
If the capacity of the underlying storage is expanded and the new capacity exceeds the PVC capacity, you need to manually synchronize the new capacity of the underlying storage to the PVC on the CCE console to ensure that the PVC capacity is correct.
  2. Locate the target PVC and click Synchronize in the Capacity column to make the PVC capacity consistent with the underlying storage capacity.
    Synchronize is only displayed when the underlying storage capacity is greater than the PVC capacity.
Helpful Links
If a storage volume fails to mount to a workload, rectify the fault by referring to What Should I Do If a Storage Volume Cannot Be Mounted or the Mounting Times Out?
