Updated on 2025-07-17 GMT+08:00
Cluster View
A cluster view is generated based on metrics and Prometheus Query Language (PromQL). It displays information about pods, containers, CPUs, memory, networks, and disks, allowing you to better monitor the running of a cluster. The following describes cluster resources from two parts: metric description and metric list. In the resource diagrams, larger values in bytes can be converted to ones in MB, KB, or GB.
Metric Description
The cluster view displays basic resource metrics, network metrics, and disk metrics.
Figure 1 Basic resource diagram
Table 1 Basic resource metrics
Metric
Unit
Pods
Count
Number of pods in different states (Failed, Pending, Running, Succeeded, and Unknown) in a cluster
Count
Number of containers in different states (Containers Running, Containers Waiting, and Containers Terminated) in a cluster
Used CPU
Core
Total number of CPUs used by all containers in each namespace
Used Memory
Byte
Total amount of memory used by all containers in each namespace
Figure 2 Network diagram
Table 2 Network metrics
Metric
Unit
Network Receive Rate
Byte/s
Total number of bytes received by all containers in each namespace per second
Network Transmit Rate
Byte/s
Total number of bytes sent by all containers in each namespace per second
Average Network Receive Rate
Byte/s
Average number of bytes received by containers in each namespace per second
Average Network Transmit Rate
Byte/s
Average number of bytes sent by containers in each namespace per second
Rate of Received Packets
Count/s
Total number of packets received by all containers in each namespace per second
Rate of Transmitted Packets
Count/s
Total number of packets sent by all containers in each namespace per second
Packet Loss Rate (Receive)
Count/s
Total number of packets not received by all containers in each namespace per second
Packet Loss Rate (Transmit)
Count/s
Total number of packets sent from all containers but not received by the recipient in each namespace per second
Figure 3 Disk diagram
Table 3 Disk metrics
Metric
Unit
Disk I/O Rate (Read + Write)
Count/s
Total number of read and write operations performed on the disk of all containers in each namespace per second
Disk Throughput (Read + Write)
Byte/s
Total number of bytes read from and written to the disk of all containers in each namespace per second
Metric List
The following table lists the metrics used in the cluster view.
Table 4 Cluster metrics
Metric
Type
kube_pod_container_resource_requests
gauge
Container resource requests
kube_pod_container_resource_limits
gauge
Container resource limits
kube_pod_status_phase
gauge
Phase of the pod
kube_pod_container_status_waiting
gauge
Whether the container is in the waiting state
kube_pod_container_status_terminated
gauge
Whether the container is in the terminated state
container_cpu_usage_seconds_total
counter
Cumulative CPU time consumed in seconds
container_memory_rss
gauge
Resident set size (RSS), which is the amount of space of physical memory (RAM) held by a process.
container_network_receive_bytes_total
counter
Cumulative count of bytes received
container_network_transmit_bytes_total
counter
Cumulative count of bytes transmitted
container_network_receive_packets_total
counter
Cumulative count of packets received
container_network_transmit_packets_total
counter
Cumulative count of packets transmitted
container_network_receive_packets_dropped_total
counter
Cumulative count of packets dropped while receiving
container_network_transmit_packets_dropped_total
counter
Cumulative count of packets dropped while transmitting
container_fs_reads_total
counter
Cumulative count of reads completed
container_fs_reads_bytes_total
counter
Cumulative count of bytes read
