Updated on 2025-11-18 GMT+08:00
Pod View
The pod view displays information about resources, networks, and disks, so you can better monitor a pod.
Metric Description
Pod metrics include resource metrics, network metrics, and disk metrics. You can view these metrics in the following tables.
Figure 1 Resource metrics
Table 1 Resource metrics
Metric
Unit
Total Containers
N/A
Total number of containers in a pod.
Running Containers
N/A
The number of running containers in a pod.
Pod Status
N/A
The number of pods in different states.
Container Restarts
N/A
The number of container restarts.
Used CPU
core
CPU used by the pod.
CPU Efficiency & Usage
- Efficiency: Used CPU/CPU request
- Usage: Used CPU/Total CPU
Used Memory
byte
Memory used by a pod.
Memory Efficiency & Usage
- Efficiency: Used memory/Memory request
- Usage: Used memory/Total memory
CPU Throttling
The percentage of the CPU time that is in throttling status.
Figure 2 Network metrics
Table 2 Network metrics
Metric
Unit
Receive Bandwidth
byte/s
The number of bytes received by a container per second.
Transmit Bandwidth
byte/s
The number of bytes sent by a container per second.
Rate of Received Packets
N/A
The number of packets received by a container per second.
Rate of Transmitted Packets
N/A
The number of packets sent by a container per second.
Packet Loss (Receive)
N/A
The number of packets not received by a container per second.
Packet Loss (Transmit)
N/A
The number of packets sent from a container but not received by the receiver per second.
Figure 3 Disk metrics
Table 3 Disk metrics
Metric
Unit
Pod Disk I/O Rate (Read + Write)
N/A
The number of read and write operations on the disk by a pod per second.
Pod Disk Throughput (Read + Write)
byte/s
Total number of bytes read to or written from the disk by a pod per second.
Container Disk I/O Rate (Read + Write)
N/A
Container Disk Throughput (Read + Write)
byte/s
Total number of bytes read to and written from the disk by the pod per second.
File System Usage
The space usage of the file system.
File System Used
byte
The number of bytes used by the file system.
Metric List
The following is the metric list of the pod view.
Table 4 Metric description
Metric
Type
kube_pod_container_status_running
Gauge
Whether the container is currently in the running state.
kube_pod_container_info
Gauge
Information about a container in a pod.
kube_pod_status_phase
Gauge
The current phase of a pod.
kube_pod_container_status_restarts_total
Counter
container_cpu_usage_seconds_total
Counter
Cumulative CPU time consumed by a container, in seconds.
kube_pod_container_resource_requests
Gauge
The number of request resources requested by a container.
container_spec_cpu_quota
Gauge
CPU quota of a container.
container_memory_working_set_bytes
Gauge
Memory used by a container.
container_spec_memory_limit_bytes
Gauge
Memory limit for a container.
container_cpu_cfs_throttled_periods_total
Counter
The number of throttled periods.
container_cpu_cfs_periods_total
Counter
The number of elapsed enforcement periods.
container_network_receive_bytes_total
Counter
Cumulative count of bytes received by a container.
container_network_transmit_bytes_total
Counter
Cumulative count of bytes sent by a container.
container_network_receive_packets_total
Counter
Cumulative count of packets received by a container.
container_network_transmit_packets_total
Counter
Cumulative count of packets sent by a container.
container_network_receive_packets_dropped_total
Counter
Cumulative count of packets not received by a container.
container_network_transmit_packets_dropped_total
Counter
Cumulative count of packets sent from a container but not received by the receiver.
container_fs_reads_total
Counter
Cumulative count of reads completed by a container.
container_fs_writes_total
Counter
Cumulative count of writes completed by a container.
container_fs_reads_bytes_total
Counter
Cumulative count of bytes read by a container.
container_fs_writes_bytes_total
Counter
Cumulative count of bytes written by a container.
container_fs_usage_bytes
Gauge
The number of bytes that are consumed by a container on the file system.
container_fs_limit_bytes
Gauge
The number of bytes that can be consumed by a container on the file system.
