- Function Overview
- Product Bulletin
- Billing
- Getting Started
User Guide
- Clusters
- Workloads
- Network
- Storage
- O&M
- Namespaces
- ConfigMaps and Secrets
- Auto Scaling
- Add-ons
- Helm Chart
- Permissions
- Settings
- Best Practices
API Reference
- Before You Start
- API Overview
- Calling APIs
APIs
- Autopilot Cluster Management
- Add-on Management for Autopilot Clusters
Autopilot Cluster Upgrade
- Upgrading a Cluster
- Performing a Pre-upgrade Check for a Cluster
- Performing a Post-upgrade Check for a Cluster
- Backing Up a Cluster
- Obtaining Details About a Specified Cluster Upgrade Booting Task
- Quota Management for Autopilot Clusters
- Tag Management for Autopilot Clusters
Chart Management for Autopilot Clusters
- Uploading a Chart
- Obtaining a Chart List
- Obtaining a Release List
- Creating a Release
- Updating a Chart
- Deleting a Chart
- Updating a Release
- Obtaining a Chart
- Deleting a Release
- Downloading a Chart
- Obtaining Chart Values
- Kubernetes APIs
- Appendix
- Billing
- Workloads
- Network Management
- Can PVs of the EVS Type in a CCE Autopilot Cluster Be Restored After They Are Deleted or Expire?
- Can CCE Autopilot PVCs Detect Underlying Storage Faults?
- How Can I Delete the Underlying Storage If It Remains After a Dynamically Created PVC is Deleted?
- Permissions
On this page
Help Center/
Cloud Container Engine_Autopilot/
User Guide/
O&M/
Monitoring Center/
Dashboard/
Using Dashboard
Using Dashboard
A dashboard integrates high-frequency monitoring metrics of different components from different perspectives. Different metrics are displayed on the same screen in charts, helping you monitor the cluster running in real time.
The dashboard displays monitoring metrics in various views, such as the cluster view and pod view.
- The cluster is in the Running state.
- Monitoring Center has been enabled for the cluster.
Checking and Switching Views
- In the navigation pane on the left, choose Monitoring Center. Then click the Dashboard tab.
The cluster view is displayed by default.
- The dashboard provides preset views. You can click the Switch View button next to the view name to select monitoring data to view.
- Configure the parameters.
- Specify the view window.
Select or customize time periods in the upper right corner of the page, and click
to refresh the page.
Parent Topic: Dashboard
