EVS Volume Overview
Updated on 2025-01-27 GMT+08:00
For persistent storage, CCE Autopilot allows you to mount the storage volumes (PVs) created from Elastic Volume Service (EVS) disks to a path of a container. When the container is migrated within an AZ, the mounted volumes are also migrated. By using EVS volumes, you can mount the remote file directory of a storage system to a container so that data in the data volume is permanently preserved. Even if the container is deleted, the data in the data volume is still stored in the storage system.
View the regions where EVS volumes are supported on the console. You can also view Function Overview to learn about all regions where EVS volumes are supported.
EVS Disk Specifications
EVS performance metrics include:
  • IOPS: the number of input/output operations performed by an EVS disk per second
  • Throughput: the amount of data read from and written into an EVS disk per second
  • I/O latency: the minimum interval between two consecutive I/O operations on an EVS disk
Table 1 EVS disk specifications
Item
Extreme SSD
General Purpose SSD
Ultra-high I/O
High I/O
Max. capacity (GiB)
  • System disk: 1,024
  • Data disk: 32,768
  • Data disk: 32,768
  • Data disk: 32,768
  • Data disk: 32,768
Max. IOPS
128000
20000
50000
5000
Max. throughput (MiB/s)
1000
250
350
150
Burst IOPS limit
64000
8000
16000
5000
Disk IOPS
Min. (128,000, 1,800 + 50 x Capacity)
Min. (20,000, 1,800 + 12 x Capacity)
Min. (50,000, 1,800 + 50 x Capacity)
Min. (5,000, 1,800 + 8 x Capacity)
Disk throughput (MiB/s)
Min. (1,000, 120 + 0.5 x Capacity)
Min. (250, 100 + 0.5 x Capacity)
Min. (350, 120 + 0.5 x Capacity)
Min. (150, 100 + 0.15 x Capacity)
Single-queue access latency (ms)
Sub-millisecond
1~ 3
API name
ESSD
GPSSD
SSD
SAS
For details about EVS disks, see Disk Types and Performance.
EVS volumes can be mounted in the following modes based on application scenarios:
  • Using an existing EVS disk through a static PV: Use an existing EVS disk to create a PV and then mount storage to the workload through a PVC. This mode applies to scenarios where the underlying storage is available or billed on a yearly/monthly basis.
  • Using an EVS disk through a dynamic PV: You do not need to create EVS volumes beforehand. Instead, specify a StorageClass when creating a PVC. Then, an EVS volume and PV will be created automatically. This mode applies to scenarios where no underlying storage is available.
  • Dynamically mounting an EVS volume to a StatefulSet: Each pod is associated with a unique PVC and PV. After a pod is rescheduled, the original PV can still be mounted to it based on the PVC name. This mode applies to StatefulSets with multiple pods.
Billing
