Using an Image Cache
In a CCE Autopilot cluster, you can create a workload using an image cache in either of the following ways:
- The optimal image cache is selected from all available image caches you have created.
- You need to specify an available image cache.
For details, see Procedure.
A CCE Autopilot cluster of v1.28.8, v1.31.4, or later is available.
- When an image cache is used, an EVS disk is automatically attached to each pod. Each EVS disk has the same size as that of the image cache and will be created and released together with the pod. Container image information is automatically stored in each EVS disk.
- When creating a workload, you can select only one image cache. If the images in the image cache cannot fully match the workload, unmatched images still need to be downloaded from the original image repository.
- Image caches are mainly used to accelerate image download. When using an image cache, ensure that the network connectivity between the workload and image repository is normal and the image download credentials are correct.
- If an image cache expires after a workload is created using the image cache, the created workload is not affected. However, if you need to perform operations on the workload, such as upgrading or scaling the workload, the image cache cannot be used. In this case, you need to download the images again.
Billing
Operation Phase |
Billed Item |
Billing Description |
Reference |
Using an image cache |
Pod |
When an image cache is used, an EVS disk is automatically attached to each pod. Each EVS disk has the same size as that of the image cache and will be created and released together with the pod. |
For details about pod price, see Billing Items of CCE Autopilot Clusters. |
There are two ways to use an image cache in the CCE Autopilot cluster: console and kubectl.
- In the navigation pane, choose Workloads. On the right of the page, select the required workload type.
- Click Create Workload in the upper right corner of the page. In the Container Settings area, configure the image cache parameters. For details about other parameters, see Creating a Workload. You can select a reference document based on the workload type.
There are three options for Image Cache. For details, see Figure 1 and Table 1. In this example, select Specify and use the cache image created in Creating an Image Cache.
Table 1 Image cache parameters Parameter
Example Value
Do not use
No image cache will be used. The images will be downloaded based on the configuration in Container Setting.
Auto allocate
The optimal images will be selected from all available image caches based on:- How much the images match the image caches: The images in the most matched images will be used.
- Time when the image caches were created: The images in the latest image cache will be used.
You can enter the name of the image to be used for Image Name (Container Information > Basic Info > Image Name). The images are matched based on the preceding rules. If no images are matched in the image cache, the image cache is no longer used. In this case, the images in the SWR image repository and open-source images are matched in sequence based on the specified image name. If no images are matched, a message is returned indicating that images fail to be pulled.
Specify
autopilot-test
Select an existing image cache. The image cache must be in the Available state. To create an image cache, click Create Image Cache. For details about the parameters, see Creating an Image Cache.
NOTE:After the image cache is specified, you need to enter the address of the image to be used in the image cache (Container Information > Basic Info > Image Name). In addition, you are advised not to select Always for Pull Policy (Container Settings > Basic Info > Pull Policy) to prevent repeatedly pulling images from the original image repository.
To obtain image path, move the cursor to the specified image cache and view Image in the displayed tip.
- Configure other parameters and click Create Workload. If the workload status changes to Running, the workload is created.
You can click the workload name in the workload list to go to the workload details page. Switch to the Containers tab to view the image cache.
The following uses an Nginx workload as an example to describe how to use an image cache by using kubectl.
- Run the kubectl command to connect to the cluster. For details, see Connecting to a Cluster Using kubectl.
- Create a YAML file for creating a workload. In this example, the file name is imagecache.yaml. You can change it as needed.
Only image cache parameters are described here. For details, see Table 2. For details about other parameters, see Creating a Deployment.
vim imagecache.yamlExample file content:
apiVersion: apps/v1 kind: Deployment metadata: name: nginx # Workload name spec: replicas: 1 # Number of pods selector: matchLabels: app: nginx template: metadata: labels: app: nginx annotations: imagecache.cce.io/specified-name: "autopilot-test" #Specifies the image cache. imagecache.cce.io/auto-match: "true" # Automatically matches the image cache. spec: containers: - image: swr.cn-east-3.myhuaweicloud.com/test/nginx:latest # Enter the image path to be used. imagePullPolicy: IfNotPresent # You are advised to set ImagePullPolicy to IfNotPresent to avoid repeatedly pulling images from the original image repository. name: nginx imagePullSecrets: - name: default-secret
Press Esc to exit editing mode and enter :wq to save the file.
Table 2 Key parameters Parameter
Mandatory
Type
No
String
Specifies the image cache. Enter the name of an available image cache. After the image cache is specified, the image information in the containers parameter must be the same as that in the image cache.
When this parameter is used, you need to enter the image path to be used in the containers.image parameter. If the specified image cache does not exist or the required images are not found in the image cache, the image cache is no longer used. The cluster will download the images based on the image information in the containers parameter.
No
String
Specifies whether to enable automatic image cache matching. The options are as follows:
- true: This option is enabled.
- false: This option is disabled by default.
After this option is enabled, the optimal images will be selected from all available image caches based on:
If no images are matched, no image caches will be used.
The two parameters indicate the two methods of using an image cache. You only need to set one of them. If both parameters are specified, imagecache.cce.io/specified-name is used preferentially. If neither of the two parameters is specified, no image caches are used by default.
- Run the following command to create the workload:
kubectl create -f imagecache.yamlIf information similar to the following is displayed, the workload is being created:
deployment.apps/nginx created
- Run the following command to check the workload status:
kubectl get deployment
If the value of READY is 1/1, the pod created for the workload is available. This means the workload has been created.
NAME READY UP-TO-DATE AVAILABLE AGE nginx 1/1 1 1 4m59s
