Managing Image Caches
View an image cache or delete an image cache that is no longer needed on the console. For details about how image caches work, see Image Cache Overview.
Viewing an Image Cache
After an image cache is created, take the following steps to view the details:
- Log in to the CCE console. In the navigation pane, choose Image Cache.
- In the image cache list, view the name, status, image, remaining validity period, and size of the image cache.
- Click Event in the Operation column of the image cache to view the events. If the image cache status is Abnormal, you can view events to locate the fault.
Deleting Image Caches
If image caches are no longer used, take the following steps to delete them:
- In the navigation pane, choose Image Cache.
- Take either of the steps:
- Delete multiple image caches: Select the image caches to be deleted and click Delete above the image cache list.
- Deleting a single image cache: In the Operation column of the image cache, click Delete.
In the Delete Image Cache dialog box, enter DELETE and click OK. If the image caches are not displayed, they have been deleted.
